2021 Chevy Equinox brake job
JTK
$100 Site Donor 2025
Buffalo, NY
I had to do pads and rotors all the way around on my 2021 Equinox AWD a few days ago @ 74400 miles. Normal rust belt blues. The brakes had a horrible pulsation that began two weeks ago, due to the pads being hopelessly fused in place, which chewed up the inside of all 4 rotors. It was a shame too as there was plenty of life left on all the pads and rotors. I believe it would have been an ideal candidate for a "brake service", 6 months or a year ago. The rotors had been supposedly resurfaced/replaced and the pads changed just prior to me buying the vehicle 2yrs ago with 34K miles on it.
All 4 rotors still had the torx screws holding them on. They all backed out easy enough after some hammer whacks, but 3 of the 4 broke off. One required drilling. Lots of rust under the abutment clips on the caliper brackets, etc. Some of the caliper pins had rust starting to form where the boot seals at the head of the pin. I wire wheeled those.
What really fought me were the rear caliper bracket bolts. The lower bolts are deeply recessed into a pocket in the aluminum knuckles, then access is blocked by a suspension trailing arm. You can barely get a finger on this bolt. The trailing arm does have an access hole through it so you can poke an extension and 18mm socket through and get onto this bolt, but there's not enough room for a breaker bar or impact unless you get creative with a wobble, etc. The hole is slightly offset from the bolt. I had to use a 1/2" ratchet with a pipe on it as they were terribly lock-taught.
For the electronic parking brakes, I opted to remove the actuators from the rear calipers. 2 torx screws hold them on, but access to one is completely blocked by a metal brake line. You have to slightly tweak the metal line out of the way to get any type of torx tool on it. Once the motors are off, the E-brake threads in easily by hand with a torx bit and then you can push the hydraulic portion of the caliper piston in all the way with your fingers.
As is my custom, I went all out with a Detroit axle pad and rotor kit for the front and a Callahan kit for the rears. All in was around $190 off Amazon. This job will be easier for me on the next go around. Just thought I'd share as we have quite a few 2018-2023 Equinox owners here.
I feel for you guys up in the Salt Belt with all the rust issues from the salt on the roads in the winter. I watch South Main Auto on You Tube and it is amazing the rust he deals with doing brakes or any repair to a vehicle.
  • Like
Reactions: JTK
I had a shop replace the rear pads/rotors on our 2018 'Nox back in Oct 2024 (77,500 miles) since they were just about worn out (found during a tire rotation) and I didn't have a bi-directional scan tool to put the stupid electric rear parking brake in service mode. I replaced the fronts in Feb 2026 (83,550 miles) and I had no issues with removing the rotor torx screws even though this car has been in Minnesota the entire time. One thing that surprised me was how clean the caliper pins were and the boots were in excellent shape. I used Power Stop fully coated Geomet rotors and the Z17 low dust ceramic pads (had great service from those before on a previous vehicle). I also bled all corners with new brake fluid too. Note- those with a FWD Equinox the front rotors are 300mm and the AWD are 320mm.
  • Like
Reactions: JTK
You had me at the Detroit Axle parts - good luck with that
I've not tried them on my GMs, but have on various Nissan, Subaru and Ram applications. No issues. My normal go to used to be Raybestos Element 3 pad and rotor kits from Rock Auto. Couldn't find them for my Equinox. Only other forms of Chineseum. I've kind of lost interest in Rock Auto anymore unless I absolutely need them. No matter what I run, you're lucky to get 40K miles out of a set of brakes where I live unless you break them down to clear corrosion and re-lube every year.
I just did the rear brakes on the wife-units 2017 Escape. There is a procedure you can do that retracts the electronic parking brake actuators- hit a few buttons in the right order. Far far simpler than removing the actuators. I feel your pain on the recessed brake caliper bracket bolts- I could not get an impact on it regardless of the number of extensions and wobbly joints. But after 3 scuffed elbows and a massive breaker bar, and a few hits of my purse, it broke loose.
  • Like
Reactions: JTK
Powerstop KOE kits are usually best choice for the one click shopping and forget it installation. I’m sure there’s nothing wrong with Detroit axles brake kits even though their parts kind of look on the lower end of the imported market. Doing a bit of research I prefer to shop rotors and pads separately now money can be saved and often could piece together a better than average pre-built kit. My choice would be semi coated rotors paired with Bosch Quietcast or Powerstop Z17 pads.
  • Like
Reactions: JTK
