What I really want to know is HOW it is detected. And is there a possibility of incorrect "detection" because it is actually inference, or calculated.
The only sensors at the wheels are wheel speed sensors, which won't tell you about fade. A pressure drop in a branch detected by DSC could detect fluid boil, but not pad fade. Reduced calculated deceleration despite continuous brake fluid pressure could do it.
And, ultimately, are there coding options available for this and other subjective characteristics of braking. For instance, could I change a coding value in my F10 to get firmer, "sportier" brake pedal feel and increasing brake torque more like my E90 had. I've read lots of things about coding F30s for the "correct" brakes when you do a retrofit and pedal feel changing. I've seen no discussion on F10s because there are not so many buyer choices of brake package per model.
