VK56VD
These were the real deal.Is there a chance they're counterfeit? I've used EBC brakes regularly since I started driving nearly 15 years ago and never had an issue.
Put Pagid FE pads and they will outperform Akebono GG in any aspect.So on the road (not track), are you saying that some EE rated semi metallic pads will have shorter stopping distance than GG rated ceramic?
And if the answer is yes, is that because of the initial bite and / or something else?
Semi-metallic pads regardless are they track or street , will create dust, whether you brakes aggressively or not.This is both city and highway miles with 400 miles after the vehicle was washed.
I’ve noticed that during more aggressive stops, there will be a thicker layer of dust on the wheels.
This car is not driven aggressively by any means.
What was wrong with Akebono? Initial bite?Put Pagid FE pads and they will outperform Akebono GG in any aspect.
I tried Akebono ceramic pads on VW. Took that junk after 3,000miles.
It is combination. Bite+compound. Compound is the most important. Would I put any FE or FF pad? No. Would I put Pagid FE over Akebono GG? Absolutely!
@VK56VD, I'm not doubting anything you've said so far, but I have a question. Besides an incredible amount of wheel dust, the rotor surface looks like it has worn excessively. How many miles were on the pads and rotors when these pictures were taken?This is the brake dust after several weeks of driving.
As expected. Passat was coming in 2008 with FE brakes, probably ATE made. Maybe, maybe FF.Interesting results in this testing;
This car is not driven aggressivelyby any means.
I had this same issue with a recent set of Akebono pads for my Yukon. I reached out to Akebobo and they sent me a new set....same thing. I changed back to the Wagner pad and now a proper fit.This brake pad has serious fitment issues. On initial brake pressure, there was a loud clunk of the pads. The pads seemed to shift slightly
The Akebono was about .5MM shorter than the OE, and Akebono acknowledged that.
Purely speculation but who knows, maybe there is a company making the backing plates, and the final material is added by the end manufacturer?
This was my new Pro Act pad in the rear of the Yukon.
They were pretty much squealing like crazy...along with the rattle.Oh! That must create a REALLY annoying thud and a slap as the pads catch.
They could turn off brake fade on BMW. Even in 2008 enthusiasts had free access to INPA software. My brake fade compensation on 328 is turned off since first day I started to track this car. I actually need to know when brake fade happens.
That might be now where tires come to play. Passat was coming in 2008 with same brake set up as my Tiguan has. Definitely not undersized.Yes but while the brake fade on the Passat was excellent, the Malibu and Accord had noticeably shorter stopping distance in a panic stop.
I get that there is more to "performance", even on the road (and depending on how one drives), but in a panic situation, what is the benefit of having better brake pedal feel if you stop 30 feet later?
No. Brake fade is pads getting too hot. Bubble bubble you are in REAL TROUBLE.Wait BMW has software controlled brake fade? I thought brake fade was brake fluid boiling and not stopping because you know bubble bubble toil and trouble.
NOTE: It is emphasized that this document does not establish friction requirements for brake linings, nor does it designate significant characteristics of brake linings which must be considered in overall brake performance. Due to other factors that include brake system design and operating environment, the friction codes obtained from this document cannot reliably be used to predict brake system performance.
