This is off topic but lets say we run a 10w/ 30 too long and it shears to a 20 wt? we run a 05w/20 too long and what happens?.
Well, apparently not! They do not want to service the vehicle under warranty.quote:
Landers Ford is the only place in Little Rock that sevices RVs under warranty.
Cathy, Any ford dealer that services Ford trucks can service this warranty. Even that full size Bronco that I mentioned was serviced in a Lincoln-Mercury dealer...we didn't even sell "Fords".quote:
Originally posted by Cathy Covington:
I don't know where else to take the RV...I DON'T KNOW WHAT TO DO!
1. It's not a heavy duty engine.quote:
Originally posted by Amkeer:
The vehicle is a motor home with an engine, V10, heavy duty, which is designed for towing. The 29,000 miles driven in 2 years would indicate that the majority was highway miles which is easy on the oil. We are not talking an automobile here. These long haulers will put miles on the oil. Truckers routinely go over 20,000 miles on oil changes
Excellent point! Ford WILL deny the claim when a non-Ford authorized attempts warranty repair. I've seen the muck that causes...don't go there. An attorney is a great idea, too. Good luck on going way over the heads of your Ford regional reps. Too bad they're so indifferent and seemingly useless.quote:
I would just hire an attorney! You can't let an independent touch it yet, that will fall into another escape clause for Ford! Just get an attorney!
Like they are doing anything for you now?quote:
Like I said, I talked to a guy in Benton and was all set to move the RV there and then I was told that Ford would back up and deny my warranty because of that.
