AutoMechanic
Site Donor 2026
I don’t mind those that’s a switch they don’t fail as much as a button would.Well, that’s one vote. I vote no.
You probably don’t like the headlight switches on the steering column either.
Yeah I know. But the number of those I have replaced is too many to count they are especially a problem on Toyota. I’ve only replaced maybe 3 ignition switches ever. When the push button start goes out it leaves you stranded it happened to some of my customers.
Or the pull rope![]()
The same thing that happens when your car just dies for no reason. Like the gallon of water in the gas you just bought. Other drivers might help you push it, or just sit and mindlessly honk and threaten you.
That said I work in the rebuilding industry, I look forward to these systems coming out of warranty so we can sell more parts.
Rod
Depends on what you're driving. My 2008 E-350 has keyless go and it's about 13 years old at this point. Still fine although the button on the shifter can have a wire break, but hasn't happened to me yet. The newer W212 model just has a button which you can just remove if the battery in the fob dies and use the key normally. It's always missing on a used car so they can be bought on eBay for about $15 if you have that option. It's aluminum so the button doesn't really wear out.Yeah but the button wears out faster after use. Much faster than an ignition would. The longest I’ve ever seen one last is 11 years till it had to be replaced.
It's a little more than that. But you can blame CAFE for that. They've been in Mercedes E class since 2014 and when they fail, it's usually the aux battery that goes bad and then the start/stop system doesn't work anymore and it doesn't shut off. People would like it that way, but then you have an annoying warning notice on the dash all the time so they end up getting it fixed. The starter just doesn't seem to be a failure point with that system. Because of CAFE numbers, they don't let you permanently shut it off, just for that particular drive cycle, have to turn it off every time you start the car. There are hacks to shut it off permanently, but they're not cheap.You're right, but I'm talking about the start/stop system malfunctioning for no reason and causing a perfectly functioning car to die, just to save .000001 MPG.
Which one are they having trouble with, the ISG or CVT?Test drove a few '20 Souls with the I.S.G. and new C.V.T.. Didn't mind it . They are having problems with it on some new SOULS and I think the FORTE as well .
This is where the 48V mild-hybrid systems excel. The battery also powers the electric motor. On my Ram, the electric motor completely eliminates the stereotypical lag during the initial throttle tip-in.I've been around and driven quite a few vehicles that have it. None have experienced reliability issues, but I personally don't like it just from a drivability standpoint. Some manufacturers implement it better than others, but there seems to be a very apparent stumble or hesitation with a lot of them when accelerating from a stop. This is more obvious with vehicles that have a hint of turbo lag on initial throttle tip-in.
Both . Go to carcomplaints.com and Kia/Hyundai owners sites for details .Which one are they having trouble with, the ISG or CVT?
This start/stop topic is one that is staring to appear on a regular basis. First of all-it's not new. It has been around at least five years. Are shops seeing failures of the components-yes but not in any large numbers.
NO-the the start/stop system doesn't use conventional starters and technology.
There are after market black boxes (for some vehicles) for less than $200.00 that plug in to the OBD ports that disable the technology as long as it is plugged in to the port.
I know there are those on here who run away like a scared cat when it comes to anything different or "new-tech".
You are going to have to keep your Crown Vics for a long time fellas.............
What’s wrong with push button start?
Even my Tundra has the equivalent. It cranks until it starts whether I hold the key or not. It’s an auto system, like push button, not like I’m holding the key and energizing a hot lead to the solenoid.
I think the OP needs to get out more often. These systems have been around for a long time now.
Start/Stop saves fuel...if only during the EPA test or real world............................it's not that we are technophobes, it's just that this is pointless new tech that creates an unnecessary failure point. I love Apple CarPlay, backup cameras, EFI, auto-on headlights, as they serve a useful purpose. This tech is really just to game the EPA test and serves no other useful purpose.
