I have my friend's 2009 Fit here and it has been more than 4500 miles since the last oil change and the Oil Life Percentage is still at 70%. More than 1/2 of the miles are from short, low-speed 3-5 mile trips with the remaining from two long trips.
From what I have read on the Fit forums, it seems that most drivers are getting around 10k between a service. On other Honda models with the Maintenance Minder system, you would see a much wider range of intervals-- but not so with the Fit. It makes you wonder if the algorithm used on the Fit's Maintenance Minder is less sophisticated than the one on other models. Here is a thread that sort of discusses this.
So, either I am dreaming or there is something very different about the Maintenance Minder on the 2nd Generation Fit. Thoughts on this subject?
