Originally Posted By: d00df00d
Originally Posted By: moving2
If you're looking for the best protection for your car, I think the question to ask is not "is there any evidence the higher Fe is causing harm?" but rather "What oil returns the best UOAs for my engine?" and Fe is one of the factors to look at.
This sounds 100% reasonable, especially as you've explained it.
However, think about what it means in practice. [...] That obviously doesn't make sense because IF the test turns out to be meaningless, the results are meaningless whether they're good or bad. That's why you have to know WHAT the numbers on the UOA means BEFORE you make your decision. Otherwise, you might as well be reading tea leaves and sacrificing goats.
d00df00d-
1. From the BITOG Oil Analysis Article:
"Iron (Fe): This can come from many places in the engine such as liners, camshafts, crankshaft, valve train, timing gears, etc. "
Would you care to provide us with a more accurate/complete explanation of what the UOA test, and the Fe reading in particular, means?
2. You seem to imply that the Fe measurement used may be invalid, and the test may be meaningless. May I ask upon what this is based? I was under the impression that Fe was being sampled and compared by Blackstone over several UOAs for a reason.
3. If my engine shows consistently higher Fe readings on UOAs with M1 vs. PU, why do you suppose that might be? Are you implying that the higher Fe might NOT be from "liners, camshafts, crankshaft, valve train, timing gears, etc."? If not, where do you suppose it is coming from?
4.
The question of this thread is this: "Does all the Fe in M1 mean to stay away?" The answer is no. Why? Because there is no reason to think that the higher iron counts mean anything bad. At all. Period.
a) If I plan to run my engine until it needs a rebuild, if the UOA Fe readings are one indicator of engine wear, would you guess that it's more likely that using an oil with lower UOA Fe readings may make my engine last longer? Or would you guess that it's more likely that the oil with the higher UOA Fe readings might make my engine last longer? Where is the evidence that it will make a difference one way or the other? You seem to state it make no difference with certainty. I am stating it may make a difference with no real certainty. Neither of us have data to back up our assertions. May I ask where your certainty comes from? And if this is an unknown, how would you justify using the oil with the higher UOA Fe readings when an otherwise-comparable oil has lower Fe readings.
b) When you say there is "no reason to think that the higher iron counts mean anything bad"- how do you know that the higher Fe counts might mean something more significant over 300-400k mi? In other words, that it might make a difference in the mileage I'm able to get out of my engine before rebuild?
d00df00d-
4.
