Coworker thinks 10w30 is obsolete
20K miles ;)
Even the 2023s? I thought they joined everyone with 0w?
No clue on ‘23s. I’ve got a ‘19 F150 3.5 and my son has a ‘19 F150 2.7 and they both specify 5w30s. I was actually going to run 10w30 in the summers until I found HPL and especially now that they’ve got the No VII oils. I’m about 1k from my first filter change & UOA (but no drain) on HPL PCMO 5w30. HPL maintains that it should be good to 15k OCI with 5k filter intervals, so we’ll see! 👍🏻
The first ones we got at work still used the heat sensitive roll paper. They were still called Fax machines though. Xerox I think, was the brand.
(edit:) Oh yeah, they still had the audible modem connection over a landline.
I remember as a kid my dad showing me the one they had at work back in the late '60s. In those days you rented it from the phone company.
FYI; Chevron 10W30 Synthetic Technology a group II & III blend CK-4/SN plus, pour point -46C, HTHS >3.5
PC Duron GEO LD 10W30 CK-4/SN, PP -44C, HTHS >3.6
Both clearly obsolete.
It performs well in the right temps, but not a good spec for vehicles that have a cold winter. Easier for manufacturers to spec an oil that performs year round. Because of this I don’t think oil companies will put as many dollars toward those product lines. I’ve used it a few times where it was appropriate but it isn’t my first choice.
For the most part, if one lives south of the WI/IL border you can use 10w30 year round. Certainly so if your car is garaged.
In Florida you could use 15w40 year-round and never have a concern.
The funny thing is many engines in the USA are given lighter weights than most European and Asian markets even though the climates are often similar.
I own a dealership so I never keep anything. But if I were to keep a car for the long haul I would 'heavily' weigh in the oil viscosities recommended in similar markets.
For example 10W-30 is a good fit for a lot of vehicles here in Georgia given the torrid heat and mild winters. If a heavier weighted oil is recommended at a place with a similar climate I would have no problem running it.
10w30 would be a great winter oil in Georgia 😂
Why would you prefer a thicker oil at start up?
Also a good example of how a relatively low pour point doesn’t always result in a superior winter rating. It still would not be desirable for starting below 0F.
Here in S. FL, 10W-30 M1 was my go-to oil for decades. 355K miles and zero problems, zero sludge or varnish. I think it's the ideal viscosity.
Same here, 10W30 for everything in fleet whether it’s a V8 or I4.
Between 1985 and 2010 all I ran was M1. After finding BITOG I started using any brand on sale.
I live below the Mason Dixon line and my vehicles are garaged and rarely cold started below 60 degrees F. I’m good with 10w30 and I’ve used it for 50 years!
