Never heard of that brand but if it's good stuff send it to me.
I think its on its way out, as I have not seen a gasoline engine spec a non-0W oil in eons.
Even the 2023s? I thought they joined everyone with 0w?Rural king house brand.
Every ford I can recall uses 5W-xx. I’ve never owned a car that specd 0W-xx
No clue on ‘23s. I’ve got a ‘19 F150 3.5 and my son has a ‘19 F150 2.7 and they both specify 5w30s. I was actually going to run 10w30 in the summers until I found HPL and especially now that they’ve got the No VII oils. I’m about 1k from my first filter change & UOA (but no drain) on HPL PCMO 5w30. HPL maintains that it should be good to 15k OCI with 5k filter intervals, so we’ll see!Even the 2023s? I thought they joined everyone with 0w?
Somebody posted a Walmart link here a while back - they went fast …Where did you get such a good deal?![]()
Well, I’ve already been shot down for thinking 10w30 is obsoleteSomebody posted a Walmart link here a while back - they went fast …
I remember as a kid my dad showing me the one they had at work back in the late '60s. In those days you rented it from the phone company.The first ones we got at work still used the heat sensitive roll paper. They were still called Fax machines though. Xerox I think, was the brand.
(editOh yeah, they still had the audible modem connection over a landline.
0W-30 optional for cold climatesEven the 2023s? I thought they joined everyone with 0w?
For the most part, if one lives south of the WI/IL border you can use 10w30 year round. Certainly so if your car is garaged.It performs well in the right temps, but not a good spec for vehicles that have a cold winter. Easier for manufacturers to spec an oil that performs year round. Because of this I don’t think oil companies will put as many dollars toward those product lines. I’ve used it a few times where it was appropriate but it isn’t my first choice.
10w30 would be a great winter oil in GeorgiaThe funny thing is many engines in the USA are given lighter weights than most European and Asian markets even though the climates are often similar.
I own a dealership so I never keep anything. But if I were to keep a car for the long haul I would 'heavily' weigh in the oil viscosities recommended in similar markets.
For example 10w30 is a good fit for a lot of vehicles here in Georgia given the torrid heat and mild winters. If a heavier weighted oil is recommended at a place with a similar climate I would have no problem running it.
Why would you prefer a thicker oil at start up?The funny thing is many engines in the USA are given lighter weights than most European and Asian markets even though the climates are often similar.
Also a good example of how a relatively low pour point doesn’t always result in a superior winter rating. It still would not be desirable for starting below 0F.FYI; Chevron 10W30 Synthetic Technology a group II & III blend CK-4/SN plus, pour point -46C, HTHS >3.5
PC Duron GEO LD 10W30 CK-4/SN, PP -44C, HTHS >3.6
Both clearly obsolete.
Here in S. FL, Mobil 1 10w30 was my go-to oil for decades. 355K miles and zero problems, zero sludge or varnish. I think it's the ideal viscosity.
I live below the Mason Dixon line and my vehicles are garaged and rarely cold started below 60 degrees F. I’m good with 10w30 and I’ve used it for 50 years!For the most part, if one lives south of the WI/IL border you can use 10w30 year round. Certainly so if your car is garaged.
