Coworker thinks 10w30 is obsolete
In the shop
Since most here know I’m a good person and I believe in paying it forward; gave my co worker with a beat to heck F-150 truck 2 5quart jugs of Providence 10w30 motor oil.
Then he says “ain’t 10w30 like obsolete?” I just walked away, and said “it’s free for gripes sake, is it not?”
I’m not using it; waiting on my no VII 5w20 from HPL Lubricants for my Focus
Is 10w30 actually obsolete? I don’t think it is
Did he refuse to take it, or was it an honest question?
Sure seems to me to be “obsolete “, not sure what, outside of OPE specs it.
10W-30 hasn't been spec'd in years by any OEM - mainly because they want to spec a grade for the entire country, and 10W in North Dakota in the winter probably isn't the best.
Also, you can't get 10w30 in every flavor - I think Mobil 1 has only 2 options out of there 6 different formulations. You will never see it on the walmart shelves either - again because most people just follow whats printed under the hood.
This is likely why people think its "obsolete".
The performance of the 5w30 oils has also gone up over the years, so that OEMs probably considered it a year-round grade.
Just because CAFE essentially requires thin oils from the manufacturers’ recommendations hardly means that the protection offered by a good 10w30 is obsolete, or unable to be enjoyed in today’s engines.
My Jeep 4.0 Liter inline-six specs 10w30. It even says it right on the oil cap, although the manual says both 10w30 and 5w30 are recommended, depending on temperature. I'm sure it wouldn't matter much in my use case, but FWIW I did have less shear down using a 10w30 vs a 5w30 in some used oil analysis I did in a previous 4.0L powered vehicle.
In the fleet world, 10W30 has largely replaced 15W40 in semi trucks. The only new diesels we get that still use 15W40 are the spotter trucks equipped with a Cummins B6.7.
Not true. Around here and WV areas and east fleets still use 15w40. Work even got 30 gallons rotella 10w30 free since trucking company’s said no thanks and use 15w40
This.
In terms of passenger car applications, I believe FCA was the last to spec 10w30 for anything. The push to have something that works everywhere from Alaska to Arizona has driven the uptake of 0W-xx in pretty much everything and even the "old holdouts" like the HEMI, which spec'd 5W-20 have now been re-spec'd for 0W-20.
Due to this, you won't see many modern approvals (dexos for example) on a 10w30 bottle. In terms of the OEM's for PCMO applications, it is indeed considered obsolete.
On the other hand, for HDEO applications, 10w30 is the new 15w40 as @skyactiv notes. Cold climates will get spec'd with a 5W-40 or 0W-40, but the "conventional" option is now a 10w30.
If ambient isn't going to get down to -25C (the CCS limit for 10W-xx) then it will be fine, obsolete or not.
I have looked into running 10w30, and interestingly all the 5w30's start at a higher KV100 than their 10w30 counterparts. I assume this must be due to the 5w having more VII to start? My primary interest is also shear - or possibly dillution. I run short OCI so it likely matters not either way, but I found this curios.
Anyone know why? Is it just more VII, or is it formulated different?
