His point is, (and he is correct), the parts have a better chance of, "remaining separated" under higher temperatures and load factors with a higher viscosity oil.Whoosh. I don’t see it.
Greetings! (-wave)Been running 0W-40 in a toyota that calls for 0w-16 in a cold state.
Has not blown up yet.
It sure did mine. I drained the 0W-16 out of it when it had only 450 miles on the clock. I replaced it with 0W-20 and noticed an immediate improvement in how quiet it was when idling at operating temperature.All of the Toyota's that I've driven recently that require 0W16 oil, was a noisy engine(upon acceleration) and I was curious if a thicker oil would quiet them down.
Japan has its own "CAFE" that regulates vehicle fuel economy, and their fuel mileage targets are more lofty than CAFE in the USA. Probably why Japan has been developing and using super thin oils for wuite awhile.Yeah, who wants better fuel economy and less smog? I remember when it used to be Japan that everyone boasted ran thicker oil but now not so much...
The same owner's manual that says it's OK to use a 0W-20, and to use a higher viscosity for more extreme use conditions. If the engine and oil pump was so sensitive to oil viscosity, the OM wouldn't say what it does.IIRC, "The Car Care Nut"(Toyota Master Tech) on YouTube says that the oil pumps in Toyota engines that require a 0W16, are specifically programmed to operate on 0W16 and we should not use a heavier oil. He also says that Toyota's 10,000 mile OCI is BS and he explains why!
Not this again. This is the biggest amount of garbage I think we’ve seen on here.IIRC, "The Car Care Nut"(Toyota Master Tech) on YouTube says that the oil pumps in Toyota engines that require a 0W16, are specifically programmed to operate on 0W16 and we should not use a heavier oil. He also says that Toyota's 10,000 mile OCI is BS and he explains why!
CAFE pulled one over Ford since they are going back to 5W-30 on some engines previously specifying 5W-20, lol. Why would Ford do such a thing and give up all those CAFE credit dollars?Edit. In before "But it's more worn out than if you had run xW30." which per the standard link to the HTHS graph someone always shares is true. Ford really pulled one over on me I guess.
How do you know that "as long as parts are sepatated" is happening well in all driving conditions? And what main factor makes parts separate better in mixed and hydrodynamic lubrication?As long as the parts are separated you are fine.
I'd say the smart money is on reduced warranty claims. Which probably exceeded the CAFE credit $$. Smart business imo.CAFE pulled one over Ford since they are going back to 5W-30 on some engines previously specifying 5W-20, lol. Why would Ford do such a thing and give up all those CAFE credit dollars?
Ford made a value decision.I'd say the smart money is on reduced warranty claims.
Yes, smart business imo.Ford made a value decision.
Drew7a: You and I think alike.Been running 0W-40 in a toyota that calls for 0w-16 in a cold state.
Your Toyota will probably last at least 400k miles with that decision, with no oil consumption or wear.I just changed oil in my Toyota. It calls for 0W-16. I put in 0W-30. I think next Spring when I change it again for the hot Summer months, I'll go with Mobil 1 0W-40 "European Formula".
Not only that. But what would happen if said engine had a crankcase full of 0W-16 in Fairbanks, Alaska in January, with a morning temp of -45F?The same owner's manual that says it's OK to use a 0W-20, and to use a higher viscosity for more extreme use conditions. If the engine and oil pump was so sensitive to oil viscosity, the OM wouldn't say what it does.
I wonder if noise is proportional to engine wear in those engines. The less noise they make, the less engine wear.It sure did mine. I drained the 0W-16 out of it when it had only 450 miles on the clock. I replaced it with 0W-20 and noticed an immediate improvement in how quiet it was when idling at operating temperature.
After that I switched to 0W-30, and it now runs unbelievably quiet. Next Summer I'm going to go to Mobil 1 0W-40 European Formula. For the cooler Winter months, I'll stick to the 0W-30. But my engine will NEVER see 0W-16 again.
I would guess there is a direct correlation between the two.I wonder if noise is proportional to engine wear in those engines. The less noise they make, the less engine wear.
I finally found a thread on BITOG where people actually think the same way I do, and I don't have to worry about getting blasted.If it were mine I'd run 5W30 in it.
Yes, to save their customers money on out of warranty engine repairs.Ford made a value decision.
