ls1mike
$50 Site Donor 2025
Heck I do it in the Caprice and Trans Am. As long as it isn't cooking oil...do it.
All true in theory, but it is a lawn mower with splash lubrication, not a complex automobile engine. The number of mowers I see every year that have been running with almost no oil, or the original oil and are fine is insane. Is xw20 optimal? No, and not recommended, but using it until the next oil change won't kill the engine, especially if he keeps up with the level, and that was my point.That's one key. The other (and at least equally important key) is to prevent metal-to-metal contact in the engine as the oil thins due to heat. An inadequate MOFT will kill the engine pretty quick. An engine full of oil at a temperature where the film thickness is insufficient won't prevent failure just because of the quantity.
Could be, maybe? For sure if you are running it near maximum output for extended periods of time, then something like a 15W40 is better. If you are mowing a few taller weeds on a dried out lawn, then anything is fine. Bogging through 8"+ of wet grass, or running 100% duty cycle on your pressure washer, probably a thicker oil more temperature tolerant oil is going to be a good idea.Running a 20-grade oil in air-cooled OPE in Houston is beyond foolish.
Why is Kawasaki recommending 50 grade oil in their engine's currently just because they must have a reason. 20 grade oil is absolutely foolish to run in Houston in a OPE.All true in theory, but it is a lawn mower with splash lubrication, not a complex automobile engine. The number of mowers I see every year that have been running with almost no oil, or the original oil and are fine is insane. Is xw20 optimal? No, and not recommended, but using it until the next oil change won't kill the engine, especially if he keeps up with the level, and that was my point.There are cars out there running 0w20 and 5w20 with much higher oil temps than a lawn mower.
Because Kawasaki engines are known to consume oil, especially the newer V-Twins, and they want to make it through warranty, not because 20 grade will blow it up on a hot day. If 5w20 couldn't stand up to high heat, Texas and Florida roads would be littered with Hondas and other vehicles with blown engines. It still amazes me that some on this forum believe OPE to have higher demands on engine oil than modern day automobiles.Why is Kawasaki recommending 50 grade oil in their engine's currently just because they must have a reason. 20 grade oil is absolutely foolish to run in Houston in a OPE.
Time for oil flushes and some @High Performance Lubricants no VII oil or Redline,Amsoil 30wtI disagree with jeepman on this. Mixing different brands and/or types of motor oil could cause problems with incompatible additive chemistries, and using 5w-20 or 0w-anything in an air cooled engine in the Houston heat is asking for trouble.
How many ounces of oil are in your lawnmower? This strikes me as an example of "trying to squeeze a nickel to make a dime". Dump the 5w-20 and install the oil that the factory recommends, 10w-30. You can also use 5w-30 synthetic (or even straight SAE30 in Houston).
Avoid motor oils with a wide Xw-X spread to minimize the amount of VII improver that is added to the multigrade oils. VII in an air cooled engine is not good. Synthetic oil contains less VII than dino oil, and SAE30 has NO VII in it.
Here are a few previous threads on mixing oils. There is also the Widman caclulator to determine your resulting grade.
https://bobistheoilguy.com/forums/threads/mixing-oils.315053/
https://bobistheoilguy.com/forums/threads/mixed-oil-debate.334979/
https://bobistheoilguy.com/forums/threads/mixing-oil.159202/
https://bobistheoilguy.com/forums/threads/mixing-oils.226210/
https://bobistheoilguy.com/forums/threads/mixing-oils-for-desired-viscosity-index.196806/
https://bobistheoilguy.com/forums/threads/mixing-motor-oil-brands.13615/
https://bobistheoilguy.com/forums/threads/mixing-different-weights-of-oil.228891/
https://bobistheoilguy.com/forums/threads/mixing-oils.325422/
https://bobistheoilguy.com/forums/threads/mixing-oils.163365/
https://bobistheoilguy.com/forums/threads/mixing-oils.120334/
https://bobistheoilguy.com/forums/threads/mixing-oils.111570/
https://bobistheoilguy.com/forums/threads/mixing-oils.2042/
https://bobistheoilguy.com/forums/threads/what-exactly-is-wrong-with-mixing-brands.202306/
https://bobistheoilguy.com/forums/threads/mixing-oils.122427/
https://bobistheoilguy.com/forums/threads/mixing-viscosities.3554/
https://bobistheoilguy.com/forums/threads/mixing-oils-again.85143/
https://bobistheoilguy.com/forums/threads/more-mixing-oils.148701/
https://bobistheoilguy.com/forums/threads/can-you-mix-viscosities-of-oil.157147/
https://bobistheoilguy.com/forums/threads/mixing-viscosities-and-or-brands-ok-or-no.349001/
https://bobistheoilguy.com/forums/threads/mixing-oil-weights.106037/
https://bobistheoilguy.com/forums/threads/mixing-different-oils.240247/
https://bobistheoilguy.com/forums/threads/mixing-oil.333464/
https://bobistheoilguy.com/forums/threads/mixing-oils-of-different-weights.186388/
https://bobistheoilguy.com/forums/threads/blending-kirkland-and-supertech-oils.367418/
https://bobistheoilguy.com/forums/threads/mixing-different-weighted-oils.196640/
https://bobistheoilguy.com/forums/threads/frankenoil-thoughts-on-mixing-viscosities.331446/
Not a valid comparison. Small air cooled engines use the oil as a part of the cooling system. Modern lean running E10 burning air cooled engines operated in high ambient temperatures (like Houston in August) at high loads (like mulching heavy grass) with a dull blade and a little grass build-up on the cooling fins for good measure can get the oil up to almost 400 degrees, WAY higher than in a water cooled engine in a vehicle. The VII in the oil will not tolerate that kind of heat before it breaks down, and the oil you are left with will not adequately lubricate the engine.Because Kawasaki engines are known to consume oil, especially the newer V-Twins, and they want to make it through warranty, not because 20 grade will blow it up on a hot day. If 5w20 couldn't stand up to high heat, Texas and Florida roads would be littered with Hondas and other vehicles with blown engines. It still amazes me that some on this forum believe OPE to have higher demands on engine oil than modern day automobiles.
I agree, but using 5w20 for one season if he keeps the oil full (by adding some assuming it burns it off) will not blow up or damage the engine like everyone here seems to think it will. Again, it's a LAWNMOWER.Not a valid comparison. Small air cooled engines use the oil as a part of the cooling system. Modern lean running E10 burning air cooled engines operated in high ambient temperatures (like Houston in August) at high loads (like mulching heavy grass) with a dull blade and a little grass build-up on the cooling fins for good measure can get the oil up to almost 400 degrees, WAY higher than in a water cooled engine in a vehicle. The VII in the oil will not tolerate that kind of heat before it breaks down, and the oil you are left with will not adequately lubricate the engine.
And that's the point really. Air cooled, operating at high ambient temperatures. It most certainly can damage the engine. As I noted, an engine kept full of oil that yields an insufficient MOFT will damage the engine regardless of the quantity.I agree, but using 5w20 for one season if he keeps the oil full (by adding some assuming it burns it off) will not blow up or damage the engine like everyone here seems to think it will. Again, it's a LAWNMOWER.![]()
Some people on this site act like it's a sin to ask a question that's been asked before.Because sometimes questions with perhaps obvious answers, do not have obvious answers
It costs nothing to post and ask
Why don't you ignore the questions if they bother you so much?That may not be all they don't understand.
Or, you can just ignore me. Do I follow you around and complain about your posts?Why don't you ignore the questions if they bother you so much?
It's hard not to "follow you around" when you complain about so many people's posts and seem to spend a lot of time looking up people's past posts to point out they asked the question before or list 20 similar posts to embarrass them. If I think a post is a waste of time I ignore it. Also, the 'Search' function on this site leaves a lot to be desired.Or, you can just ignore me. Do I follow you around and complain about your posts?
I don't hesitate to mix viscosities or brands for the sump in an automobile or truck. But for a small capacity sump like in most OPE, why worry about using up a half quart of 5w-20? For your use, I'd go 10w-30 synthetic all day long.
I should have qualified by saying "in an older automobile or truck."I don't hesitate to mix viscosities or brands for the sump in an automobile or truck. But for a small capacity sump like in most OPE, why worry about using up a half quart of 5w-20? For your use, I'd go 10w-30 synthetic all day long.
