Thankyou for answering my question the way I was trying to ask it. My truck has piston slap and the 5w30 always seemed to make the noise louder and last longer. Maybe others have had different results, but for me I have been using Pennzoil Platinum10w30 ever since. As long as I did not mess anything up by mixing them, I thought a thinner 10w30 would be an ideal blend and then note how the truck responds to it. The Impala is not fussy at all, so this was thought out for the truck use only. Both need changing now, so I have a jug of each and that was the reason to ask you guys first. I don't care if the truck is wearing out faster with thick oil, I just wanted to minimize the noise. I just didn't know how the two would react, if at all. Thanks again.. (Quote)
Oils blend fine together. Using the viscosity calculator on Pennzoil Platinum specs you find that thw 5w30 is 57.5 at 40c and the 10w30 is 63.4 at 40c. Blending the two gives you a viscosity of 60.37 at 40c. You will not find that the two fluids separate or layer in the sump, they are 1 fluid with a slightly different viscosity than either of the originals. The 30 weights on the hot end are virtually identical. I don't see an advantage to the blend, because the oils are so close in specs. I think you could use the 10w30 in both and be fine.
[/quote]
beanoil is on the right track. BTW I think those are the Pennzoil Platinum SM spec's you've quoted.
Blending a 5w30 oil with a 10w30 oil will likely produce a lighter 10w30 oil, meaning it will likely no longer pump at -35C. Pennzoil Platinum 10w30 is heavier at all temp's to Pennzoil Platinum 5w30 even at very hot operating temp's. That's because it has a higher HTHS viscosity (3.1cP) and a lower viscosity index (157 vs 177).
A 50/50 blend will give you a light 10w30 with a 167 VI on par with the average synthetic 5w30 at typical operating temp's.
Pennzoil Platinum 5w30 is the lightest OTC 30wt oil generally available in the States so blending with Pennzoil Platinum 10w30 will thicken the oil up a little bit, primarily on start-up. If you can notice the difference then the blend may suit your needs.
[/quote]
