Originally Posted By: CKN
I'm waiting for someone to say they mix witches brew in a vehicle worth more than 20grand. We will be waiting a while.......
Not too long.
I would, did and will continue to do just that.
I have mixed M1 with Valvoline conventional (both 5w30) in a $20,000+ Trailblazer. Mobil 5000, 1 qt M1, and 1 qt Pennzoil Platinum once and then Valvoline conventional, Valvoline Durablend and M1 another time in a $20,000+ Grand Caravan, I know I mixed brands and weight (5w30 and 10w30) several times in a $20,000+ Dodge Ram.
Not sure why vehicle value makes a huge difference in if someone would do it or not. I treat my new vehicles the same as my old ones. I want them to last as long as possible, regardless of value.
Sure I try to stick with one oil during an oil change, but extra bottles need to be used at some point. As said before, how many add a qt of top off oil that is different than what was used at the oil change with no ill effects?
My brews have almost always been to use up what is left over, once did I mix purposefully to make a syn blend (same brand and weight, just a 50/50 conventional/syn blend), and once mixed some xw-20 to thin out some xw-40 that I had no other use for (different brands also, but both conventional oil).
Heck, my truck (not worth $20,000+, so I guess some would say it is a beater?) has a brew in it. Why, because I had 3 qts of 5w-20 Nextgen and needed 6 for the oil change, so I used some 5w-20 Pennzoil Platinum I had laying around to get 6 qts. I could have used 3 qts of several other oil in my stash (12 qts Castrol GTX Blend, 15 qts Quaker State Synthetic, 12 qts Havoline HM, 10 qts Valvoline Syn, 5 qts Mobil 1 Advanced Fuel Economy, 6 qts Auto Zone Syn) but it would have made me short on oil changes later on. I am not trying to accomplish anything except use oil that I have.
As for the OP, the manager is just covering his rear. I mean they did do it after all.
