mechtech2,
I take your approach to mixing oils.
For example, the '97 Accord now has 2+2 Mobil 1 Extended Performance 5W-20 and 30.
Why?
The 5W-20 was on clearance for 2.94 at Walmart in the spring.
There were only three qts on the shelf, which I bought, figuring I would find a use for it.
A couple of months ago, Kmart had EP at 5.00/qt, and Mobil had a MIR of 10.00 on five qts, so cost works out to a reasonable 3.00/qt.
So, I now have eight qts of Mobil 1 Extended Performance at 3.00/qt, enough for two changes in the '97 Accord.
Another example would be the case of GTX 5W-20 I bought to mix with and use up a case of GTX 20W-50 left over from an old Mercedes we used to own.
So, I agree that mixing like with like is the safest route to take.
Also, while I wouldn't waste anything expensive, the occasional orphan quart or two can always become lawnmower juice.
