This is my first post, not a lub-nube but a semi-complex question: I just bought a Kohler 20kw air-cooled 3600rpm generator with a CH1000 series engine. The application is for the backup of a solar power system. The plan is to run it (after warm-up) at 90-100% load for 3-4 hours a few times a year when the battery bank gets too low due to weather or other problems. The location is at 8,500ft in Colorado. The air is thin, so the generator will tend to run hot. However, it will probably run the most when the insolation is least (winter) at -25 to 30 degrees F, but there will be times it will run in all seasons with ambient temperatures up to 100°F.
The generator owner's manual says 5w-30 synthetic, the CH1000 engine owner's manual says 10w-50 synthetic. The engine is used in lots of applications, from riding lawn mowers to pumps and construction machines. However, a generator will run at 3600 rpm all the time.
Because it will start when the batteries reach a low state of charge, after warm-up, it will run for an average of 3.5 hours every time it is run. For efficiency, it makes sense to load it heavily.
Running at 3600 rpm at a high altitude under heavy load, what is the best weight oil in summer and winter? I have already decided it must be a 0w-xx oil because of winter starting temperatures. In the summer, it can get over 100°F with thin air/poor cooling, so am I better off running a 0w-30, 40, or 50?
If possible, I want to change the oil only once a year, with probably no more than 16-32 hours of run time per year.
