"Twist the cap to break tamper proof band and access FunLPro hose. Grab and pull vertically on FunLPro hose until firm resistance is felt. Place FunLPro pouring hose in to desired destination and evacuate fluids."I'm aboard! How 'bout that built in pouring spout?
It doesn't get any better than that.
They use several ASTM standards plus an NMMA corrosion test and outboard motor tests …Just as the title says. My local Walmart had 1 gallon jugs of 10w30 for $5 each. Figured at the least it’ll be good for OPE.
Any issues with using in a car with catalytic converters or at least at a minimum used for top offs?
Have you ever tried pouring oil into a marine engine?I'm aboard! How 'bout that built in pouring spout?
NoMagna1 Lubricants = MAG1 ?
Only while standing on the ground with the fill hole at eye level.Have you ever tried pouring oil into a marine engine?
Try with an inboard it standing on you head!Only while standing on the ground with the fill hole at eye level.
Use whatever floats your boat dude.
