Flip a coin. Seriously. You're making this way too complicated.Okay Motul 5w30 x-clean+ or 5w40 x-cess. Again NA 93oct pump. And go!
Unless X-Cess GEN2, go X-Clean +. That oi looks really stout.Okay Motul 5w30 x-clean+ or 5w40 x-cess. Again NA 93oct pump. And go!
Okay one last question before ending this topic. I'm sure everyone is tired of the noob . As mentioned LL01 has a specific test for chain wear. After reading a few LL04 spec'd tech doc it meantions LL04 also includes all specs from LL01. Just curious as to what makes the difference. Does LL04 carry LL01 specs by default?Some BMW tunes retain warranty (Dinan for example). Your engine is recommended to use LL17FE, LL14FE, LL01FE and LL01.
IMO, LL01 is only one acceptable if wear is concerned, especially tuned engine. Yes, B generation is DI, like all BMW engines since 2010. So, what you want is high HTHS oil. Motul X-Cess Gen2 5W40 has HTHS 3.8. That is ver good for KV100 of 13.5. You could also go Pennzoil Platinum Euro 5W40 that is on sale in Advanced Auto Parts all the time. Reason why I would stick to LL01 is that it has specific test for timing chain wear. Your timing chain is in the back, not front like previous BMW engines, and you really, really don’t want to do TC work on an engine like that.
The reason for that language is that on European market BMW started to use LL04 instead of LL01 in 2009.Okay one last question before ending this topic. I'm sure everyone is tired of the noob . As mentioned previously on the first page LL01 has a specific test for chain wear. After reading a few LL04 spec'd tech doc oils it meantions LL04 also includes all specs from LL01
One from Motul for example: "It covers all BMW engines from 2004 and also all BMW engines before 2004 as BMW LL-04 covers all the previous BMW specifications such as BMW LL-98 and BMW LL-01"
Is this a misinterpretation or specific for this oil?
So just to be clear, the LL04 does not include the same testing as LL01?The reason for that language is that on European market BMW started to use LL04 instead of LL01 in 2009.
Mostly. LL04 is lower SAPS, emission after-treatement compatible (DPF and GPF). So they do have bit different tests. But, nuts and bolts are same. LL04 is basically LL01 just Lower SAPS.So just to be clear, the LL04 does not include the same testing as LL01?
My 2 cents, having taken a look at running low-SAPS in my N55 last summer when I was forced to pick a new oil because they stopped selling my current choice...
1/ I am very familiar with the TIS "suitable engine oil" grid which is no longer easy to link to. I'm pretty sure I took a PDF copy of it that I could post. It has said no LL-04 (more or less equivalent to LL-01 but low SAPS) in North America for decades. This was due to high sulphur permitted in, and found in the fuels which dramatically decreased the service interval because low SAPS means lower ability to fight acid build up.
A lot has changed, even in the two years since that bulletin has come into effect, with sulphur level restrictions coming into place in both the US and, finally, Canada in that time. These changes put sulphur levels on par with Europe where LL-04 is permitted. I expect that those "suitable engine oil" bulletins could be updated. Whether they are is probably a matter of whether anyone at BMW HQ cares enough to bother since there are so many other products to choose from and the older engines will all have warranties and dealer support expire.
2/ You're asserting that the advantages of running LL-04 "against recommendation" would be shown in a UOA. They won't. The benefits will be shown by having less build up on your intake valves and the rest of your intake manifold. These benefits do not show in an OC or two, but over years of operation. What you WOULD see in a UOA is that there is no disadvantage from a lubrication and wear standpoint to running LL-04, and you would need to monitor TBN and TAN for a while to verify that your choice in fuel has appropriate sulphur levels and that you are changing "often enough" (whatever that is for your application).
Disclosure - I ended up sticking with LL-01 this time around, but I am still considering going LL-04 and monitoring closely via UOA with TBN/TAN. My annual mileage is low and I change oil way earlier than the factory interval anyways so I'm probably a good candidate to give it a shot.
You really do not understand this, do youHere's BMW's recommendation re: potential intake deposits:
00 21 11 (715)
Petrol additive - we recommend regular use with petrol engines
Applies to: Russia, Brazil, Italy
Situation:
Regular use of fuel additives is recommended to prevent coking of intake valves and injectors (in direct fuel injection).
Vehicles concerned:
All BMW, MINI and Rolls-Royce with petrol engine.
Procedure:
We recommend adding two cans of petrol additive to the fuel tank upon each engine oil change:
Customers should be advised during every service appointment to regularly use BMW petrol additive. We recommend adding one can of petrol additive to the fuel tank each time when refueling.
- When fuel tank full:2 cans of petrol additive
- When fuel tank half-full:1 can of petrol additive
BMW part number: 83 19 2 183 738
MINI part number: 83 19 2 350 552
I wish I could find VW's procedure for this, but from what I remember of my days on vortex, golfmkv, and golfmkvii the official technical procedure was to hold the revs over 3000rpm to so the valves hit around 600*C and cook off any carbon.
Maybe super dooper oil can mitigate some of this, or maybe not.
Has BMW spec'd LL-04 for newer petrol models in the US? I know the Golf 7.5 generation started moving to VW508/504 at some stage I think.
All I know I was happy to have 0w-20 in my sump on a -2*F morning!
He is using thinner version of LL04, but he is not aware of it. Let him do some more hits.This does not apply at all to Direct Injection. If you google/youtube search "direct injection" and "intake deposits" you'll end up with lots of hits from every major manufacturer, complete with pictures, borescope video, animations on principles etc...
When dealing with DI engines, oil choice is directly relevant to intake deposits and no amount of fuel additives will help.
BMW isn't the problem here.You're probably correct BMW has no idea what they're talking about with their own engines, and are lying to their paying customers who access TIS.
BMW also says not to use additives.You're probably correct BMW has no idea what they're talking about with their own engines, and are lying to their paying customers who access TIS.
Did you actually comprehend this TIS? Here's the cliff notes: Poor quality gas can result in deposits which impact the performance of injectors. A compromised spray pattern creates more carbon deposits. This has nothing to do with the choice of motor oil.You're probably correct BMW has no idea what they're talking about with their own engines, and are lying to their paying customers who access TIS.
I think the hole in your logic is that if the FE-17+ standard is an enhanced LL-04, why has BMW still not seen fit to approve it for vehicles in North America?BMW also says not to use additives.
And, BMW is already using low-SAPS oil in their engines in order to reduce CBU. You are actually using it, but you do not know why.
Did you?Did you actually comprehend this TIS? Here's the cliff notes: Poor quality gas can result in deposits which impact the performance of injectors. A compromised spray pattern creates more carbon deposits. This has nothing to do with the choice of motor oil.
Btw this document applies to only three countries (Russia, Italy, and Brazil) for a reason.
Yes I did. So I'll connect the dots. The increase in carbon deposits from poor combustion would increase the amount of those deposits making their way to the back of the intake valves. Basically there's two sources of valve deposits. The ash level in the oil oil and the quality of the combustion. The primary contributor is the choice of oil at least in the US where top tier fuels are readily available.I think the hole in your logic is that if the FE-17+ standard is an enhanced LL-04, why has BMW still not seen fit to approve it for vehicles in North America?
Bimmerworld suggests that fuel in the US has had parity with the EU since around 2014, so surely BMW has had the time to evaluate LL-04 for our market.
Engine Oil Info for BMW
BMW engine oil info and recommendations from the leading independent BMW tuner in the USA.www.bimmerworld.com
"BMW never certified LL-04 for the US market because a) there weren't many Diesels for sale here, b) it was incompatible with the high amounts of sulfur and Ethanol in US gasoline. However, since 2014 our gasoline more closely matches European sulfur levels. US sulfur remains higher so if you're using a LL-04 oil you should change it more often as sulfur will dilute the oil (5,000 oil change interval should be sufficient). Oil analysis can give you more insight how your local fuel is interacting with the oil. LL-04 and LL-01 are interchangeable/compatible but LL-04 is preferred for BMW turbo engines for its higher ZDDP and low SAPS. Food for thought: the official BMW Motorsport oil recommendation for the M4 GT4 race car is a LL-04 spec oil. Our race team uses Red Line Euro Series 5W40"
I'm pretty sure you can run any synthetic oil if you're just going to throw it away at 5k mi.
Did you?
It clearly states both intake valves and injectors; and I would bet Italian petrol of all things is comparable to the US.
This is kind of what I'm getting at, in that boutique oil is only a small part of preventing coking in direct injection engines.
Italian tune-ups or approved manufacturer additives will net the same result.
BMW doesn’t plan to use high HTHS oils in the US anymore, therefore no need to bother with TIS about LL04 and complicate stuff even more.I think the hole in your logic is that if the FE-17+ standard is an enhanced LL-04, why has BMW still not seen fit to approve it for vehicles in North America?
Did you?
Do UOA so we know how it did. Gen2 is new stuff, not much outthere.Sorry to revive this but wanted state what I ended up choosing. Went with Motul 5W-40 X-Cess Gen 2. Shall see how it works out. While its not cheaper than most OTF options, its about the same price for the "GR Supra C5 oil" from the stealership.
Thanks for advise and the wealth of knowledge everyone.
