US gasoline used to eat BMW Nikasil cylinder liners. That was attributed to the high sulfur content in US gas.What evidence is there (if any) that NA fuels have high (reletive) sulfur?
Absolutely. And thanks for the help.Do UOA so we know how it did. Gen2 is new stuff, not much outthere.
That is not indication of whether oil is in good or bad shape.Changed the oil over the weekend in my 340i, was easy but not quite as easy as my old MK7 GTI.
Miss having that oil filter front and center, as opposed to rear and right - which requires something like a u-joint to get at it properly.
Went with 0w-20 LM 6600: https://www.fcpeuro.com/products/0w-20-top-tec-6600-engine-oil-5-liters-liqui-moly-lm22046
The 5 litre jug was nice for disposing the old oil into, and less of a chore than filling up 7x 1 litre bottles.
Old oil was dealership 0w-20, as it was my last free maintenance; the used oil seemed still in good shape and wasn't overly black/dirty.
Filter was perfectly clean, no lego blocks or sparkly bits.
That said, given corona and WFH - only did about 7000mi this 12mo interval.
Lots of short trips, extreme weather, and the like.
Ya that timing chain on the rear of the engine really buggers up access to the oil filter housing. I was surprised that BMW didn't opt to design the block for a spin-on filter with these B-series engines.Changed the oil over the weekend in my 340i, was easy but not quite as easy as my old MK7 GTI.
Oh, so OFHG is going to be a breezeYa that timing chain on the rear of the engine really buggers up access to the oil filter housing. I was surprised that BMW didn't opt to design the block for a spin-on filter with these B-series engines.
I know right. It's no longer one but instead 2-3 smaller gaskets.Oh, so OFHG is going to be a breeze![]()
Let’s hope.Looking at TIS, it involves removing:
DME
Coolant Expansion Tanks
Auxillary Oil Pump
Underbody paneling/support
A million hoses and cables
etc etc
There's 4 gaskets on the oil cooler, and 5 on the oil filter housing itself.
Suffice it to say, hopefully BMW learned their lesson with the leaky N5x series.
Most of the engine is glued together with silicone, so that's something of a relief.
US gasoline, when compared to European gasoline, had a relatively high sulphur level. Years ago BMW was installing M60 V8 engines that had Nikasil cylinder lining. BMW ended up replacing many of these engines for free because US gasolines with high sulphur were eroding the Nikasil.What evidence is there (if any) that NA fuels have high (reletive) sulfur?
Yeah back then. My old 530i with the M60 engine had it replaced but I actually knew someone who had an M60 that wasn't driven much during that time, and survived to live when the sulfur levels dropped. He drove it up until a couple of years ago when subframe rust finally made it unsafe to drive.US gasoline, when compared to European gasoline, had a relatively high sulphur level. Years ago BMW was installing M60 V8 engines that had Nikasil cylinder lining. BMW ended up replacing many of these engines for free because US gasolines with high sulphur were eroding the Nikasil.
https://en.wikipedia.org/wiki/BMW_M60
I don't see anything 'fine' about these. And most are break in samples.https://www.supramkv.com/threads/black-stone-report.2656/page-2#post-139644
Looks like the Toyota 0w-20 C5 does just fine, even under tuned/catless applications with substandard air filters.
A stock B58 on a diet of highway driving post-Covid world shouldn't have any problems.
Motul X-Clean+ 5W30 has an API rating of SM, not SN which is required for turbocharged engines.That engine is designed around heavy W30 and lighter 40 grades. But, you could pretty much run anything in it. There is no such thing as overkill.
Take into consideration that when you say "grade" that is KV at 100c. Your BMW in regular driving is running around 109-113c. That means that at regular driving, your oil is bit thinner than you think. That is why HTHS is important and not grade per se. There are different oils, some meeting minimum requirements, some exceeding it. Generally, oils with lower KV100 but really good HTHS are top of the line oils. Motul Gen2, Castrol 0W40, Castrol Edge 0W30, Pennzoil 5W40, etc. are all superb choices. Motul X-Clean+ 5W30 would be prime example of superb oil, as it has KV100 of 11.6 and HTHS of 3.6 and it is LL04. Valvoline European Vehicle is at 13.1 KV100 and HTHS 3.7, which is really good.
Again I would go with approved oils for LL01 and LL04, regardless of weight.
If you decide to track vehicle, than we are getting into different conversation.
Ya, its like a 14 hour job.Looking at TIS, it involves removing:
DME
Auxillary Oil Pump
etc etc
What are you talking about? Please enlighten us!Motul X-Clean+ 5W30 has an API rating of SM, not SN which is required for turbocharged engines.
OP: Stick with BMW TPT 0W30. Buy it at FCPEuro for $10 a liter.
Where is the API SN requirement for a turbocharged engine listed? I've been using Castrol Edge 5w30 LL in my Tiguan which as far as I can tell does not have any API licenses. Am I damaging the turbocharger?Motul X-Clean+ 5W30 has an API rating of SM, not SN which is required for turbocharged engines.
Wait, your turbocharger didn’t die yet? Or at least quit in protestWhere is the API SN requirement for a turbocharged engine listed? I've been using Castrol Edge 5w30 LL in my Tiguan which as far as I can tell does not have any API licenses. Am I damaging the turbocharger?
Hows the Mobil 1 ESP 0w30 compere to the Mobil 1 ESP 5w30? I was thinking to move to this oil when winter comesWait, your turbocharger didn’t die yet? Or at least quit in protest
Edit: man I just saw that Mobil 1 ESP 0W30 also doesn’t have API. I am done. My wife will kill me when turbocharger fails on Tiguan.
Yep,Euro approvals are weak, API strong. Get your facts right. /sWait, your turbocharger didn’t die yet? Or at least quit in protest
