I should have written "Ravenol VMP 5W30 from BlauParts for my B58."I went with Ravenol 5W30 from BlauParts for my B58.
Yeah! I refuse to run 0W20. It's way too thin and its HTHS is too low..
Excellent choice. That's what I run in my GTI.
LL04 is listed for the B58 in the handbook of my 21 model 745LePer BMW's technical documentation system (TIS), LL-01, LL-01 FE, LL-14/17 FE+ are listed as compatible with the B58 - with 0w-20 17 FE+ as being the 'recommend' oil.
This could be due to CAFE/EPA considerations, or due to the fact that 20 weight warms up quicker and flows more quickly to lubrication points - especially during a start/stop cycle.
It also states that LL-04/12 should not be used in North America for gasoline engines.
No.Sorry to bump an old thread as OP, but since Mobil 1 FS 0W-40 is now LL-01 approved, would there be any benefits/disadvantages to switch over Motul X-Cess Gen2 5W-40 (other than price)? Motul is what I have been running for the last few changes and have used oil analysis. Driving type hasn't changed. Thanks!
Well, I would prefer the API SP Mobil 1 0W-40 to the SN formulation of X-Cess Gen 2 just for peace of mind regarding LSPI. If we are talking about the new SP formulation of X-Cess Gen 2 then it is probably also a top notch choice. I would probably prefer X-Clean Gen 2 in a B58 though assuming your manual allows for LL-04.Sorry to bump an old thread as OP, but since Mobil 1 FS 0W-40 is now LL-01 approved, would there be any benefits/disadvantages to switch over Motul X-Cess Gen2 5W-40 (other than price)? Motul is what I have been running for the last few changes and have used oil analysis. Driving type hasn't changed. Thanks!
Corporate Average Fuel Economy (CAFE). BMW won't recommend LL01/LL04 in the US because their vehicles were certified on the 20w and FE 30w oils.I am not sure why they have different specs in the US
But LL04 is one of the option sin the handbook in the UK for the B58 in my car.
BMW dealers use LL04 when servicing, the car is specced for 0w20 aswell, witho it double checking LL17 FE
You didn’t find a good answer in this thread?Bumping this up again as I have a B58-powered BMW out of warranty and now with 40k miles. I'm looking for a good oil and would prefer it be available at Walmart or the local auto parts store, etc. and not necessarily something I would have to obtain via an online order.
I have read pages so far of the CAFE fuel-economy vs. wear issues and it seems something with an LL-01 rating would be ideal.
(For what it's worth, my manual recommends LL-01 FE or LL-14 FE+ in a 0W-20 or 0w30 grade).
Looking to keep the car long-term, it has an engine tune and hi-flow downpipe.
I live in the Mid-Atlantic where temps are generally 20-30F in the winter and 90+F in the summer.
The car is driven about 10k miles year and does a fare share of idling in the winters and summer, mostly around town-driving, short commutes to work (about 9 miles one way) etc.
Mobil 1 FS 0W-40 seems to fit the bill and now is LL-01 rated. Are there any others I should consider as well?
Finally I am relying on the BMW oil change monitor to alert me of changes needed...it has generally been about 10,000 mile OCIs. Should I be changing more frequently?
Pennzoil Platinum Euro L 5W30 will do it. LL17FE is basically thinner version of LL04.Bumping this up again as I have a B58-powered BMW out of warranty and now with 40k miles. I'm looking for a good oil and would prefer it be available at Walmart or the local auto parts store, etc. and not necessarily something I would have to obtain via an online order.
Thanks - why do you recommend the Castrol Edge 0W30 over the other brands and viscosities?Pennzoil Platinum Euro L 5W30 will do it. LL17FE is basically thinner version of LL04.
If you want LL01 Mobil 1 0W40, Castrol Edge 5W40 and 5W30 A3 will do it.
But personally, I would go Castrol Edge 0W30 available on Amazon.
Bcs. IMO it is still best Euro oil.Thanks - why do you recommend the Castrol Edge 0W30 over the other brands and viscosities?
A lot of oils will be stout and a lot have those two approvals together.Thanks again edyvw. I think I found it at Amazon:
Castrol Edge A3/B4 0w30 Advanced Full Synthetic Motor Oil
https://www.amazon.com/Castrol-0624...4&sprefix=castrol+edge+eurp+0w,aps,111&sr=8-4
Elsewhere I was reading that any oil with both LL-01 and Mercedes 229.5 certifications would be a very stout oil for the B58. Does this make sense?
What about Pennzoil Platinum Euro LX 0w30?Pennzoil Platinum Euro L 5W30 will do it. LL17FE is basically thinner version of LL04.
