Originally Posted By: Hokiefyd
You're running 215/85R16s? That's an awfully skinny tire.
Yeah, something sounds wrong with your '08. My folks' '06 TJ Rubi was a slug. I've never had much love for that 4.0L engine, though. My family has owned three Jeeps with that engine, and it lasts a long time. That's about all I like about it. There are other engine designs that last a long time, too, and do a lot of other things better.
Anyway, yeah, the 3.8L should easily outrun a 4.0L Wrangler. My neighbor has a 2008 Wrangler Unlimited Rubicon with the stock 32.1" tires (255/75R17), and it does great.
The 215/85R16s you run on yours are only 30.5" tall. It should be a rocket (relatively speaking anyway).
I was using those tires for comparison - those are the winter tires. Skinny does better in the snow. They used the same set of tires on both Rubicons (had to run tubes in the 2004 rubicon ... had to buy another set of wheels for the 2008).
The tires on my Cherokee measure a hair over 31 (and are taller than your average "32" inch tire) because they are recaps. Also are significantly more heavy because they are load range E truck tires on 16'' steel wheels.
Originally Posted By: Norm Olt
215/85-16 was the standard LT tire size for almost 15 years of Ford F250 trucks... Hauled many a ton of camper, dirt, etc. in both 2WD & 4WD applications.
Around here it is probably one of the hardest size used tires to find, especially in the higher load ranges.
Not cheap, either.
Cheers!
p.s. Lots and lots of 17", 18", 20" "truck/suv" tires are available in as many different profiles as you can imagine. Now load rating is another story...
I like skinny tires - the way they perform and the way they look. That was around the only skinny "31" I could get on my Cherokee. My other option was 32x9 swampers but they were too expensive.
I bought treadwright mud tires in that size - because it's so common and the casings are so common, I paid $120 a tire to my door!
Originally Posted By: SteveSRT8
I am confused why manufacturers still insist on stupid tall gears for vehicles when we have transmissions with two or even more overdriven gears!!
Our Silverados with 3.23's get LESS gas mileage than the same truck with 3.73's. Same engine, weight, trans, everything.
Stupid tall gears do well for the EPA test and that's about it.
