The saga continues.
Had an excessively busy fall, so I didn’t mess with the car much. Today I went to install a decent low mileage cam I got from Latvia, with all new lifters.
I removed the junkyard cam. No issues. Put in the new lifters, lubed everything up, put on the replacement cam.
I started to tighten the cam tower bolts by hand, then started the half turn regimen by ratchet. When that felt tight, I got the torque wrench set at 18 ft-lb. When I got to bearing 4 (iirc) I tightened the next half turn, could feel the torque, and then bump! A weird jolt. I continued doing the towers per the FSM. Later I was torquing #7 to completion and, pop!
Ugh. I snapped my cam.
Twice in fact.
Unbelievable. Stupid tax for sure.
So now I’m shopping for another late model one with low mileage. I think I have a lead…
Beyond frustrating though!!
I’m trying more than anything to reconcile what I did wrong. This is the third cam install I’ve done. I haven’t snapped any others on install or removal.
I see it could be one of two things:
1) the new lifters all got dunked for a second in fresh oil just to coat all surfaces. I didn’t work them or try to purge them. Could I have gotten excess oil someplace that made them not want to give?
2) on all the other jobs, I started the loose bolts and screwed them all in at the same number of turns. This time I was a bit more casual with it, thinking that if I just started torquing together when the bolts were down at the caps, it would be ok. Maybe I got the caps sort of crooked relative to the cam (one of the two bolts was turned in more) causing a misalignment and stress even though the cam was pretty well tightened in.
I’m leaning towards #2.
@Trav eo you have any thoughts on this? Im disgusted at the mistake and waste of money and time. I don’t want to let it happen again.
