- Joined
- Feb 7, 2025
- Messages
- 31
I have a 2006 Jeep Wrangler with the 4.0 motor and 188k miles on it. I've owned the vehicle since 110k miles and have changed my oil every 5k with Rotella T6 10w30. A couple weeks ago, after long drives, the motor would idle rough and would throw a P0303 code. I initially thought this was a heat soak issue as the 4.0s are known to have this problem on the third injector. I replaced the heatshield, replaced the injectors, and insulated them. No difference. Recently, it has gotten a little more common. It usually throws the code after a 30-40 minute drive now, but sometimes, it runs just perfectly fine. It's very random. I tried all the little things:
-Checked the grounds and wiring
-Replaced the coil
-Replaced the plugs
-Moved injector over to see if misfire followed
-Disconnected the O2 sensors
-Checked that the third injector was getting power when misfiring with a noid light
-Replaced camshaft position sensor
-Cleaned IAC and throttle body
Still getting the misfire. I took it into a shop a couple days ago and they said I needed a new motor. Thought it was strange as it would run perfectly fine most of the time? No lack of power or anything, and still decent gas mileage (for a Jeep). They said compression was between 100-110 on all cylinders and was at 90 on cylinder 3. I asked them to do a leak down test as well and they said that cylinder 3 had 90% leakage. This is where I am confused. Would I not have significant drivability issues if I truly had 90% leakage? Wouldn't the misfire be more consistent? And how are they getting 90 psi on cylinder 3 with that much leakage? Should it not be significantly lower? They also told me they were not able to determine where the leak was coming from. I thought that this was the point of even doing a leak down test. Is one not supposed to listen for the leak?
Anyways, I don't know how well the previous owners maintained this vehicle. I ran a bottle of Rislone engine restore in hopes to loosen up any junk in the top end and drove the Jeep for about 220 miles, stop and go. i thought for a second it might have actually solved my issue. NO rough idle during that drive until I pulled back into town and into my parking garage. Then I got the rough idle again and threw the code. So I'm not sure what's going on here. I'm skeptical that I need a new engine as the numbers do not really make sense to me. I even tested the compression myself a while back and got around 170 psi on all cylinders but that was also 20k miles ago. Maybe I did something horribly wrong within that time period. Oil analysis came back from Blackstone around the same time and everything looked great.
Are my issues likely caused by a dirty engine? Or do I seriously have mechanical issues on a Jeep 4.0 with less than 200k miles?
-Replaced the coil
-Replaced the plugs
