adventureboss
- Joined
- Feb 7, 2025
- Messages
- 38
I have only had the Jeep for the past year and a halfish, and am at 190k now. Must have bought it June 2023. I drive quite a bit. The symptoms I'm having are the occasional rough idle, and then misfire codes. Other than that, nothing. Only throws the misfire code at idle as well, no issues when driving around. It seems very random. I ruled out everything except the engine.When did you buy this '06 Jeep with ~110k.?
What are the symptoms which got you to "chase a P0303 code"?
Did you always have some indication of misfire or hiccoughs?
How do various cooling system components look?
Maybe your car had a 'hot lunch' during its previous ownership?
The cam lobe and valve spring inspection mentioned is a good idea as it's so inexpensive to do [on that engine].
The involved valve or valves might not be traveling smoothly.
Also mentioned above was a water treatment (decarbonizing?) which was described as only benefiting the cylinders.
Maybe hit the intake with a solvent spray? Or borescope the intake runners for gunk?
How's the PCV system?
Where's your guy sourcing the head?
Funny you mention the cooling system, I'm not sure what the previous owners did but they took zero care of the cooling system. There was so much sludge and the Jeep would overheat or get very close to it (250F+ coolant temp) until I replaced the entire cooling system and flushed the block out dozens of times. I'm sure part of the reason I'm having this issue is because of that. Poor motor did not live an easy life. Who knows how many times the PO overheated it as well.
I think carbon build up may have been an issue with this motor as well. I remember clearly when I first bought it and got on it hard a ton of smoke came out the tailpipe and the cats needed replacing shortly after.
I am very sure it's the valves. I've done seafoam, the sprays, anything someone could think of honestly. I wish I had access to a borescope to check. With almost perfect compression now I don't know what else could be leaking. I don't think there is really a PCV system on these Jeeps, but also I'm not too familiar with how they work so I could be misinformed. As far as I know, there is no PCV valve to replace or clean. I did clean the idle air control valve though just to rule it out.
I believe it is a new head from cylinder head express. I am skeptical because I don't know much about them but there's also not many options. My mechanic said that his machine shop was not willing to rebuild my original head because the exhaust valve seats apparently usually go bad and it's not easy to machine those, or something like that. I'll hang onto it anyways.
