urman
Archoil AR6900-P test:
Think I'm a bit confused. What's the actual result?
Oilsyn for regular usage, BG products, Techron, Archoil 6900Based on your tests so far, what is the most cost-effective cleaner for you?
Techron and Gum Out Complete are the two I usually reach for at WM for good price & availability (used right before an oil change) . I’ve also used Redline SL-1 at the rate of 2 oz. per tank of gas as a maintenance dose.I am looking forward to this test, Redline and Techron are the two brands that I have used, I feel like the engine runs better after Techron, not so much after Redline.
No, but I guess it’s should be the same as LM:Hi urman, have you tested any Wurth products?
Man, if this had been applied on my 75w90 thread for gear oils I’d have had coffee for a looooong time…
What a great idea! I did it. Let's keep this young man properly caffeinated.
The BG “Deposit Control Additive in Fuel Test” #995DCA (roughly) measures Nitrogen content in a sample, not PEA (or TEA, or PIBA) content. A urine sample would score very high, as the test does not distinguish between PEA and pee (or melamine, protein, etc.).Glad others brought it up......you buy him a coffee, I'll buy him a 1/2 Keg!
This must've cost him a small Euro Fortune. I was going to call BG last week but forgot to ask about what the Reagent is. Anybody?
I can't believe after all these years of debate, something like this dyi PEA checker self test exists at a consumer level. I must be dreaming.
Unless its not testing for PEA but some kind of other derivative.
Molekule, you have anything to say on this BG potion & Magic Show test methodology?
