- Joined
- Jul 22, 2022
- Messages
- 830
Personal engine oil struggle. Dramatic thread title for sure.
Good/smart move on your part. No one should ever assume just because one uses a certain shop/dealership that they are going to always use what we expect them to. I would use the dealer service department, yet bring in your own oil and filter. I have done that route for so many years. Matter of fact I always do that when we purchase a new vehicle until it is out of warranty. Once warranty is up , I then do the changes at home. Enjoy the new machine!If I go the TGMO route, which would be the easiest, I will pay an extra $20.00 per service to use the 5 qt. of 0w-16 TGMO of the shelf. I will not use their bulk oil. I already looked into this. Thanks
Would you why that so? Mexico is notorious for thicker oil.The same engines made in Japan and exported to Australia can drink 5w30 according to the Australian manual although the manual in Japan says 0w-16 or 0w-8.
Such a rebel you are.If the dealer won’t use the Castrol 0w-20 that I hand them during of the free oil changes
Today's Kendall is a step-up from Mobil Super Synthetic in yesterday's TGMO jugs and bulk tanks. So I suppose Toyota is trending up in oil selection nowadays. But those yesterday's TGMO high MOLY levels are now l-o-n-g gone.Can't go wrong with tgmo. If it's about cost it's a little more expensive than the rest. I just hate the individual quarts id rather have a 5 quart jug to deal with, just makes it easier to bring in for recycling
It’s actually a green silicone ADBV. And you won’t find a Japanese made filter at your dealership except for the filter used on the new TT V6 Tundra.Here in Canada, I went to a Toyota dealer with the intention to purchase 0W16 TGMO and a Toyota filter for the first oil change on my 2024 Prius. Like you, I was keen to get the high moly considering 0W16 oil.
They brought out a 5 quart jug of Mobil 1 Advanced Fuel Economy 0W16 for $45 usd or they had 1 litre bottles of TGMO for $14 each ($70 total). I just bought the Toyota Filter and walked over to Canadian Tire and bought a jug of the exact same M1 for $26 usd.
Once I was into the oil change I realized that the filter they sold me is a different part number than the original and made in Thailand rather than Japan. Next time I’ll probably use a Fram Ultra filter - the original filter looked good inside but I don’t trust the one they sold me - black abdv and I found some poor efficiency test results on this website.
This is what the Australian manual says:Would you why that so? Mexico is notorious for thicker oil.
Not at all. The rate of break-in metals is falling off exponentially because it’s much, much higher those first few hundred miles.And 325 miles is still too early for an OC.
You sure it's not at 357 miles?Not at all. The rate of break-in metals is falling off exponentially because it’s much, much higher those first few hundred miles.
All those wear particles are not helpful for break in. EVERY new engine should have the factory oil changed within the first 500 miles.
When I was a test engineer, we did 3 pulls of 20 minutes on the torque curve to break in a new engine. The oil is then drained and the sample of the resulting refill was taken as the “baseline” and would be the reference for the daily oil samples that followed the remainder of the test (up to 1500 hours on some tests)You sure it's not at 357 miles?
Might want to start running Valvoline Restore and Protect. Your rings are likely clogging.130,000 miles on my 2020 RAV4. 0w20. Mostly all Suoertech or Kirkland every 10,000 miles. No towing. Lots of high-speed highway miles. No issues.
You are re-living Automobile Dark Age Production. Engines are digitally master-cut these days.Not at all. The rate of break-in metals is falling off exponentially because it’s much, much higher those first few hundred miles.
Even if it doesn’t burn oil?Might want to start running Valvoline Restore and Protect. Your rings are likely clogging.
Yes. Rings can be dirty without large amounts of burn if the cylinder bore hasn’t worn too much yet. If it burns oil, irreversible damage has been done. Freeing the rings can improve the rate of burn, but the wear is permanent.Even if it doesn’t burn oil?
I'm going to keep doing what I've been doing. We can use my vehicles as controls.Might want to start running Valvoline Restore and Protect. Your rings are likely clogging.
There are no material differences in tolerances or processes now that there was 10 years ago. Unless you want to argue that CJ4 oil was terrible and CK4 is super duper more betterer.You are re-living Automobile Dark Age Production. Engines are digitally master-cut these days.
3k is short enough.
872.7 miles or bust.You sure it's not at 357 miles?
