Probably calibrated for different regions. Best to not chance it. Might shear off of the drive shaft on the pump or something. Very sensitive ECM circuits.Why would it affect the oil pump based on this. Or is it sarcasm.
LOL! I think it would probably affect the VVT, since that is regulated by oil pressure, oil flow and the car's ECM's. Somebody in an Internet video got this "electric oil pump" thing going a while back. I don't think that part is true.Did the manager mention how it affects the electric oil pump? I hear those things are finicky.
So it is sarcasm, nice I like a good laugh.Probably calibrated for different regions. Best to not chance it. Might shear off of the drive shaft on the pump or something. Very sensitive ECM circuits.
What an incredible, versatile engine!I have used in my 2.5 dynamic force Rav4 engine 0w-16 (free dealer changes), 0W-20 once because thats what I had, and 5w30 now. It continues to motor down the road somehow, seemingly uncaring.![]()
It was the care care nut guy who I remembered saying this, as if Toyota keeps a shelf of 64 different oil pump designs country specific. You know, the same company that literally has used the same dimension and design of spin on oil filter for every 4 cylinder engine since the 1980s and militantly streamlines their design process to have common parts across as many vehicles as possible...yes this company will make 64 variants of an engine, right?LOL! I think it would probably affect the VVT, since that is regulated by oil pressure, oil flow and the car's ECM's. Somebody in an Internet video got this "electric oil pump" thing going a while back. I don't think that part is true.
No, VVT is moved by oil pressure but controlled by the ECU. The oil pressure is simply used as the motive force. If the ECU wants VVT to move it lets in or lets out more or less oil pressure into the VVT solenoid. If the oil pressure was too low to do this you would have other far worse problems. Some VVT models have been known to fail when the screen going into the solenoid gets plugged due to oil change neglect.LOL! I think it would probably affect the VVT, since that is regulated by oil pressure, oil flow and the car's ECM's. Somebody in an Internet video got this "electric oil pump" thing going a while back. I don't think that part is true.
I think you need to start more threads on this topic. Its a numbers game, and eventually, you will get the answer that you want. Otherwise, it'd be far smarter to just trust Toyota's manual and use 0w-16, because they know their engines better than anyone else on this thread. Get a hobby, and relax.Actually, the owner's manual does talk about 5w30, saying if you are using it, it could make the engine harder to start in cold weather. It doesn't say you can't use 5w30 or you have to use 0w-16. Neither is required that you do or don't. As the district guy said, he has nothing on it. The only thing that does matter is if I want the Toyota Care services, the dealer will have to install their 0w-16, unless I want 5w30. If their 5w30 is the same price or cheaper, the oil change will still be free, otherwise I will have to pay the difference in price. There is a lot of "preferred" or "recommended" wording in the owner's manual, there is nothing "required" when it comes to engine oil. As the district guy said, "I have nothing on this, use 0w-16, 5w30, or something in between. It has no effect on your Toyota warranty." Now, this is just me talking now, but I think if I was dumb enough to go and put in say 20w-60 or something stupid like that, it would likely break something, that would be my fault, not Toyota's. And also, as I was informed today, these same exact 2025 engines in different parts of the world do actually "recommend" or "prefer" the owner use 5w30. That is not made up. Anyhow, it is 5w30 or 0w30 for me. If my gas milage drops too much, maybe I will go back to the 0w-16. I doubt it will though, I went through this with my previous SUV, milage didn't drop enough to notice.
You are right, it is a numbers game. This has already been beat to death on this thread I started. I have my answer. I wanted to run 5W-30 or 0w30 in my new Toyota. Yes, I can run those viscosities if I want to, it will not affect the Toyota warranty one way or the other if the engine messes up somehow. This is according to Toyota corporate. The 0W-16 is done to get a little closer on government fuel milage goals, it has nothing to do with increasing the durability of the engine and service life. I have been running 0w30 engine oil for a while now; there is no noticeable loss of fuel milage we see in this SUV. Obviously there has to be a little better fuel milage somewhere under some circumstances noticed by the engineers, I mean common sense dictates a thinner oil would flow easier than thick oil, taking less energy to pump it through. As far as that goes, water probably flows good too. And besides all that lovcom, I like worrying about engine oil and lubricants in general, this is kind of a hobby to me by itself. Obviously, Toyota knows their engines quite well, they build some of the best mass-produced products out there. Anyhow, as I said, I got the answer I am looking for already, from Toyota, the car runs great, and I am happy. Take Care.I think you need to start more threads on this topic. Its a numbers game, and eventually, you will get the answer that you want. Otherwise, it'd be far smarter to just trust Toyota's manual and use 0w-16, because they know their engines better than anyone else on this thread. Get a hobby, and relax.
That's right. I'm currently installing the optional heavy duty oil pump drive chain so I can run a 30 weight. j/kIts also not a electric oil pump. Its electrically controlled but chain driven.
Exactly - which is the paragraph that I use to justify the 5W30 and now, 0W30 in my Tundra that specifies 0W20.They never have. The owners manual simply states that a higher viscosity may be suitable under certain operating conditions.
Same. Out of warranty, I don't care, but Toyota is saying: there s a reason why we say that.Exactly - which is the paragraph that I use to justify the 5W30 and now, 0W30 in my Tundra that specifies 0W20.
You’ll never out drive 0W16 or 20 everAccording to the Toyota district service manager for this part of the country, I can run 5w30 in my Rav4 without hurting my warranty. However, doing the "Toyota Care" services, the Toyota 0w-16 will have to be used. I don't give a hoot about the Toyota Care services. I whited out names and e-mail addresses.
Nope. Won’t affect VVT at all.LOL! I think it would probably affect the VVT, since that is regulated by oil pressure, oil flow and the car's ECM's. Somebody in an Internet video got this "electric oil pump" thing going a while back. I don't think that part is true.
