Not clean enough for me; too much varnish.
And what is it hurting? Nothing. Who cares if there is a bit of varnish? The car will run to 300K+ looking a lot worse.
Originally Posted By: zeng
Originally Posted By: The Critic
Vehicle had 102k - prior oil change history (up until the 98k mark) was every 4-5k using Mobil or Pennzoil conventional 5w-20. The cover was removed because I did a valve adjustment on the engine.
1 )Looks like to me the 5W-20 minerals had caused permanent damage to the :
a )All single cam-lobes (inlet?) of all 4 cylinders, and
b )the 2 cam-lobes (exhaust?) of Cylinder No 2.
The 6 cam-lobes has very clear and wide rubbing marks around the lobes that had overheated to a
very high local temperatures as witnessed by gold yellowish stains then progressively to light
blue burning marks , further overheated to dark blue/grey dark colored marks.
The engine consumes approximately 1 quart of oil every 5,000 miles.
2 )I interprete it as likely caused by (1) above and stucked piston rings . However the oil
leaks could also be other reasons like mal-functioning valve seals etc.
The wear patterns are normal. If half as much damage as you are thinking had occurred, then valve clearance would be off by a mile, not a few thousandths of an inch.
