JHZR2
Staff member
My Accord Hybrid has been running great on 0w-20 as well....We just finished 157k on a Fusion hybrid … trouble free vehicle/engine on 0W20 (zero top ups in 10k OCI)
Original brakes …
Original brakes …
Why don't you look at the VOA got TGMO 0w-16 that is on this forum?The HTHS of 0W-16 (and thinner) oil is below what is generally considered the minimum needed for reasonable engine protection. I think the minimum HTHS for good protection is considered to be around 2.6, and the 0W-16 oils are around 2.3 (and please correct me if I'm mistaken).
What techniques, additives, and base stocks are needed for such a thin oil to provide adequate engine protection over a wide variety of conditions and a period of many years? What elements of engine design are important to help the oil do its job? How is oil dilution dealt with? Seemingly, 0W-16 is doing an acceptable job for some engines. How do they do it?
Don't take this as me being "anti-thin oil" but I do have to ask....And their engines don't blow up from oil failure.
They change the oil how often ? I'm guessing daily. How frequently do they tear down/re-build these engines ? Weekly ?
That said, obviously they want the absolute minimum amount of friction (presuming thinner oil means lower friction).
I'm certain of it..Tech Talk #98 – Oil Is Everything
By David Reher, Reher-Morrison Racing Engines “It’s better to allow a little trash to circulate inside the engine than to risk a catastrophic failure due to insufficient oil flow.”…rehermorrison.com
David Reher is a very smart engine builder. We are very proud to be the only oil David recommends on his site based on his experience with our oil.
I have put soon 600K on my last three Ford Duratech 4 cyl engines including my two Fusions with trouble miles with the engine. To date no oil consumption in my normal 10K OCI with M1 20 wt. oils.We just finished 157k on a Fusion hybrid … trouble free vehicle/engine on M1 0W20 (zero top ups in 10k OCI)
Original brakes …
Some are using an even better oil - 0W3
Yep, you read that right, 0W3.
THREE.
It's about what works in that engine, with those operating conditions, not about oil X is better than oil Y based on one number viewed in isolation.
Toyota did design a variable-output oil pump, controlled by the PCM. However, it’s more of an efficiency thing.I would assume larger bearings and higher oil pressure.
We better stopThis is not the old days. Things change and engines and oil are not excluded from that.
“Paranoia strikes deep
Into your life it will creep
It starts when you're always afraid
Step out of line, the man come and take you away”
The Prius is a known oil burner due to that fact - but I think it’s a mix of low-tension rings for less pumping loss combined with start-stop that’s causing the rings to come up. And it’s intentionally undersized to move something that’s about the same weight as a Corolla around. I’m running a stout 5W-30 in a gen 2, but M1 0W-20 ESP(or similar ACEA Cx or MB 229.7/BMW LL-17FE/VW 508.00 approved oil) would be my pick in a newer one if it wasn’t as expensive as it is.The hybrids that will turn off their engines after long climbs and accelerations? I can see the potential for heat soak in the bearings, and all of a sudden you do have lots of start-stop scenarios at HTHS type temperatures in the bearings for a short period, but potentially the worst case period, no flow, low RPM, very hot, collapsed hydrodynamics, etc...
I may come back to buy some more of your oil, my engine is really smoothing out and I will do my best to get some filters to a forum member that cuts them open. I documented a timeline of your EC product to the white filter I put on a few days later in the thread.Tech Talk #98 – Oil Is Everything
The Japanese were the first to jump on the “thin” oil bandwagon - Toyota started using 5W-30 in the 1990s, Honda started using 0W-20 from the factory as early as 1999.
Remember why the HTHS viscosity parameter was invented. It's because the oil can run at near 150C in the journal bearings while it's shearing at a high rate, even though the oil in the sump is at 100-120C. So you don't have to be screaming down the Autobahn or on a track to get the oil at 150C in the bearings. In those cases, you better have way more HTHS viscosity than 2.6 cP.Shel, HTHS is measured at 150C. It’s a great data point if that oil is going to be run on the autobahn, or pushed hard in a high performance engine. But in a Camry? Driven to the grocery store? The oil won’t ever see that temperature.
As has been discussed many times in these kinds of threads, when film thickness between moving parts due to viscosity (the MOFT) can't cut it (ie, when metal-to-metal contact happens due to zero film thickness), then the film strength (from the AF/AW additives) of the oil has to kick in to help reduce wear.Well, I'm not really discussing my Camry, rather, I'm interested in the details of how the oil is designed so that it provides adequate protection.
Your posts, as well as many others in this thread, are scientific, factual, and well reasoned and expressed.As has been discussed many times, when film thickness between moving parts due to viscosity (the MOFT) can't cut it (ie, when metal-to-metal contact hapoens due to no film thickness), then the film strenght (from AF/AW additives) of the oil has to kick in to help reduce wear.
The first line of wear protection is from the viscosity, and the second line of protection is from the film strenght.
