Hello everyone. I have some questions about using a different viscosity of oil than specified by the manufacturer. I know the prevailing wisdom is to avoid doing this – the engineers know more than I do, etc. But I think I have found a scenario where it is warranted. After thinking about this carefully, the decision is much more complex than I envisioned. I need to hear the prevailing wisdom of this group.
My family has owned 4 Toyota Tundras over the years, and I am now contemplating buying my fifth. I am well aware of the failing main bearing issues with the new turbocharged V6, but we are sticking with this choice. It is this problem, plus my operating conditions that are causing me to re-consider what oil to use. Here is the scenario.
- I live in Phoenix, AZ, where high temperatures during the summer hit 115, sometimes frequently and for a month or two at a time. Winter temps seldom go below 30.
- The Tundra engine has dual turbochargers, direct injection, variable valve timing, and (I think) a variable oil pump.
- The 2022 – current turbo V6 engine is well known for having excessive wear of its main bearings, sometimes leading to seizing of the engine. These engines are getting replaced by the manufacturer for the most part, but naturally I would like to avoid this situation. I suspect using an oil with a higher High-Temperature High Shear (HTHS) would help. I don’t think use of 0W-20 is the primary cause of these bearing issues, and an oil with higher HTHS won’t guarantee this problem doesn’t happen, but I believe it would help, especially in my high-heat operating conditions.
- The owner’s manuals for these engines spec a 0W-20 (which I have been using for years in my other vehicles)
- Higher HTHS – which would help with bearing wear.
- The Dexos-R spec has much more stringent Low-speed pre-ignition requirements than Dexos-1 Gen 3.
- The Dexos-R spec has extremely stringent requirements for deposits in turbochargers in high-heat conditions – and this engine has two turbochargers.
- I think variable-speed oil pumps are calibrated according to the viscosity of oil that is recommended – can anyone confirm this? If that’s correct, using a 40-weight instead of a 20 weight could cause the oil flow to be significantly reduced – since at a given pressure, a higher-viscosity would flow less at a given pressure than a lower-viscosity.
- I have heard variable-valve timing engines (like this one) use oil pressure to control valve timing. A 0W-40 might cause valve timing to be altered from using a 0W-20 weight. Comments?
- Naturally, there could be warranty concerns.
