You are free to post references to these problems so we can all be as convinced as you.Yes they are.. Are you a mechanics in a dealership? Or someone work in RnD?
Are you aware of the relationship between viscosity and temperature?Yes they are.. Are you a mechanics in a dealership? Or someone work in RnD?
I'm agreeing with you, just about everything with cars is better now.I wonder if these temperature charts for oil are remnants from the old days? Back then it was common to see cars overheat in the middle of summer.
I have driven my car with temperatures in the teens and temperatures over 100. My engine temperature reading on the instrument panel is the same, about 215-220. I imagine most cars are like that now.
The longer the trip, the higher the viscosity you need? Or does it stay "in grade"Are you aware of the relationship between viscosity and temperature?
A short-tripped car in Calgary will see much heavier viscosity running 0w-16 then the same car run in Florida on 5w-30 or even commuting to Toronto in SW Ontario. Engines CANNOT be as sensitive to viscosity as some assume, otherwise, cold climates would be plagued with engine failures.
The point is that operating viscosity is dramatically different from what corresponds with the number on the bottle. If an engine is tested with 0w-16, it should be fine, regardless of ambient temperature with that grade in the pan. However, in application, ambient temperature as well as usage profile both play a significant role in what the actual operating viscosity is that the engine sees, and that's why engines cannot be as sensitive to viscosity as some believe.The longer the trip, the higher the viscosity you need? Or does it stay "in grade"
Oil viscosity isn't chosen because of the oil pump design. Oil viscosity is chosen based on the engine components design - and it's pushed to the limit of "just how low can you go" driven by CAFE. The PD pump is designed to ensure adequate oil volume is supplied to all the moving parts without over pressurizing any components, like the oil filter and oil seals, etc that may not be able to take too high an oil pressure. The use of a pressure relief valve in the PD pump ensures nothing gets damaged from excessive oil pressure.Force feeding the bearings are fine but given you have the oil pump at a standard what does higher than normal PSI mean as to your choice in oil viscosity? Suppose you know the RPM and oil temperature and know the target PSI. Ferrari adjusts the oil viscosity recommended by the oil PSI.
Wear is in the lower RPM and cold oil. And that starts with the 0w and then goes mainly to that 212 F point, unless we are talking track cars.
What kind of problems?There are already some cases of 2.5L and 3.5L camry D4-S that has problems from using 5w-30 instead of 0W-16. It was information from Master Diagnostic Level Mechanics in a dealership. It is up to you, your cars, and your money for repair.
Off course, it is in American made Toyota in the range beyond 200 000 km problems.
You can overdo any thing. The engine bearings are designed for oil flow. Every exit for the oil PSI is in parallel with with one source, the oil pump. Too thin of oil has problems as too thick. There is CAFE and there is what the engine is engineered for. 30% of engine cooling depends on the oil flow. Oil temperature varies inside the engine. IMO the engineered oil flow is directly proportional to viscosity even though we are talking about a positive displacement oil pump because there are multiple outlets for that oil can go. There is a perfect viscosity for every engine. The only way to determine is the PSI. I always think of the main bearings but the pistons have oil jets that spray under the pistons. Same as low SAPS. Sulfated ash is used in the engine valve seats and piston rings. Always a happy medium.Oil viscosity isn't chosen because of the oil pump design. Oil viscosity is chosen based on the engine components design - and it's pushed to the limit of "just how low can you go" driven by CAFE. The PD pump is designed to ensure adequate oil volume is supplied to all the moving parts without over pressurizing any components, like the oil filter and oil seals, etc that may not be able to take too high an oil pressure. The use of a pressure relief valve in the PD pump ensures nothing gets damaged from excessive oil pressure.
Oil pressure is a result of forcing a given oil volume through a given oiling system flow resistance at a given viscosity. It's better to have adequate flow of oil to all engine components at a lower oil pressure then it is to have inadequate oil flow at a higher pressure. Engineers design an oiling system and the PD pump as a total system to achieve adequate (or more) oil flow within a reasonable operating oil pressure range.
You keep talking about flow when the most important thing is the MOFT.You can overdo any thing. The engine bearings are designed for oil flow. Every exit for the oil PSI is in parallel with with one source, the oil pump. Too thin of oil has problems as too thick. There is CAFE and there is what the engine is engineered for. 30% of engine cooling depends on the oil flow. Oil temperature varies inside the engine. IMO the engineered oil flow is directly proportional to viscosity even though we are talking about a positive displacement oil pump because there are multiple outlets for that oil can go. There is a perfect viscosity for every engine. The only way to determine is the PSI. I always think of the main bearings but the pistons have oil jets that spray under the pistons. Same as low SAPS. Sulphated ash is used in the engine valve seats and piston rings. Always a happy medium.
It's not a question of trip length, it's a question of oil temperature. Some engines will develop high oil temperature over a long trip. Most will not.The longer the trip, the higher the viscosity you need? Or does it stay "in grade"
As already mentioned, the oiling system is designed to ensure proper/adequate oil flow to ALL required components so that they do not fail from oil starvation. We have seen some engine designs where there are component failures regardless of what oil viscosity it used because the lack of oil flow is a very bad thing and causes moving parts to smoke themselves in pretty short order.You can overdo any thing. The engine bearings are designed for oil flow. Every exit for the oil PSI is in parallel with with one source, the oil pump. Too thin of oil has problems as too thick. There is CAFE and there is what the engine is engineered for. 30% of engine cooling depends on the oil flow. Oil temperature varies inside the engine. IMO the engineered oil flow is directly proportional to viscosity even though we are talking about a positive displacement oil pump because there are multiple outlets for that oil can go.
Not really. More like there is a perfect viscosity for every engine based on the use conditions of that engine in a specific environment.There is a perfect viscosity for every engine. The only way to determine is the PSI. I always think of the main bearings but the pistons have oil jets that spray under the pistons. Same as low SAPS. Sulfated ash is used in the engine valve seats and piston rings. Always a happy medium.
Okay, well explained.. I may need to read it several times but, if it is hot out and driven hard, the engine oil may be different viscosity than what it says it normally is.The point is that operating viscosity is dramatically different from what corresponds with the number on the bottle. If an engine is tested with 0w-16, it should be fine, regardless of ambient temperature with that grade in the pan. However, in application, ambient temperature as well as usage profile both play a significant role in what the actual operating viscosity is that the engine sees, and that's why engines cannot be as sensitive to viscosity as some believe.
Under the MOFT should never happen with the recommended viscosity oil. But wear metals will show if you get a UOA and MOFT is not met. By the way my 2019 Miata takes 0w-20. In Europe they give two choices of Mazda oil 0w-20 and 5w-30. Guess what oil viscosity you think the Miata guys swing to. I have TGMO in there now but ordered Pennzoil Ultra Platinum 0w-20 for the next fill.You keep talking about flow when the most important thing is the MOFT.
By "in grade," I would be asking.. does it retain its HTHS or possibly other SAE J300 properties that would keep it as a 20, a 30, a 40.. a 50, a 16. So.. would the oil become "less than," which is why some believe you need to go thicker.It's not a question of trip length, it's a question of oil temperature. Some engines will develop high oil temperature over a long trip. Most will not.
They will reach a steady oil temperature that is a function of engine load, engine operating temperature, and environmental factors like outside air temperature and air density.
When you say, "in grade" are you meaning deterioration of oil performance? Or do you mean in increase in temperature, that changes the operating viscosity of a particular grade of oil?
If an engine is ran very hard on a race track for instance, of course the oil will be much hotter than if it was just cruising down the highway at much lower RPM. When you're cruising down the interstate in high gear at 70 MPH the engine revs are really pretty low, and therefore the oil temperature will only be around 200-220F. Plus, cars get better cooling when cruising at 70 MPH then they do cruising around town without 70 MPH flowing into the front end. On a race track that same vehicle might get oil temperature near 275-300 depending on some factors.Okay, well explained.. I may need to read it several times but, if it is hot out and driven hard, the engine oil may be different viscosity than what it says it normally is.
Okay, new questions before I really need to hit the road, for a night of driving until the sun comes up.. dont Ram Air and airflow also help cool? I always felt the cooling system was the #1 thing keeping engine temperature, including indirectly oil, temps in check, and how car manufacturers got to spec their 20-grade (now 16-grade seems to be what is next) oils.If an engine is ran very hard on a race track for instance, of course the oil will be much hotter than if it was just cruising down the highway at much lower RPM. When you're cruising down the interstate in high gear at 70 MPH the engine revs are really pretty low, and therefore the oil temperature will only be around 200-220F. On a race track that same vehicle might get oil temperature near 275-300 depending on some factors.
Only if the oil is thick enough to ensure that moving parts don't excessively rub on each other. The thinner the MOFT becomes, the more rubbing contact will occur. It's the whole backbone of tribology and the basic correlation between oil viscosity and MOFT (film thickness) that has been true for 100 years.Under the MOFT should never happen with the recommended oil. But wear metals will show if you get a UOA.
That’s not supported by reality. It’s the reason “acceptable” wear came into use by automakers.Under the MOFT should never happen with the recommended oil. But wear metals will show if you get a UOA and MOFT is not met. By the way my 2019 Miata takes 0w-20. In Europe they give two choices of Mazda oil 0w-20 and 5w-30. Guess what oil viscosity you think the Miata guys swing to. I have TGMO in there now but ordered Pennzoil Ultra Platinum 0w-20 for the next fill.
Air flow into the engine compartment helps dissipate heat off the engine. Heat is also lost through the oil pan. Most modern cars have a water-to-oil cooler which helps keep the oil temperature down. Just like the link I posted above, even in a modern engine using a water-to-oil cooler, the outside ambient air temperature effect can still be seen on the oil temperature.Okay, new questions before I really need to hit the road, for a night of driving until the sun comes up.. dont Ram Air and airflow also help cool? I always felt the cooling system was the #1 thing keeping engine temperature, including indirectly oil, temps in check, and how car manufacturers got to spec their 20-grade (now 16-grade seems to be what is next) oils.
Not asking to be difficult. Asking because we are talking about it. I'll read reply when I can.
