Here are my compression readings since 200k miles, when I started keeping records of compression tests on this car:
Tests at 202k, 212k, 234k, 265k, 289k miles.
Cyl #1 149, 140, 145, (A-RX), 154, 156
Cyl #2 150, 143, 150, (A-RX), 151, 146
Cyl #3 151, 146, 146, (A-RX), 144, 148
Cyl #4 149, 147, 139, (A-RX), 148, 151
Cyl #5 144, 144, 144, (A-RX), 140, 149
Cyl #6 144, 146, 150, (A-RX), 145, 151
Average 148, 144, 147, (A-RX), 147, 150
Air temp ???, 60F, 73F, (A-RX), 60F, 43F
Average of all tests = 147.2
Compression tests will vary a little, of course. The only reading that was out of line was cyl #4, and it was right before I ran A-RX. Because that cylinder was fine before that test and went back to similar readings with subsequent tests, I think it was most likely a test glitch, maybe a piece of dirt keeping the tester from sealing perfectly. If you throw it out as a bad number then the test right after A-RX is exactly equal to the average of all the other tests, as statistically close to "no change" as is possible.
It is possible that the one low reading was caused by a deposit that was cleaned by the A-RX. What are the odds that the #4 cylinder just happened to get compression-impaired by a cleanable deposit right before the A-RX, after 200k+ miles of running as clean and strong as the other cylinders? I think it is less likely than simply a faulty reading. However, I don't know for certain.
I could throw out the data points for for #1 on the second test and #5 on the fourth test, which were also a bit out of line, and that would would inflate one pre-A-RX test and one post-A-RX test and make no difference overall. Either way you look at it there is no clear statistical improvement before/after A-RX, especially when you consider that the latest and best test was on the coolest day, which by itself would account for the higher reading.
Keep in mind that these tests were all done at 5850' elevation, so you have to add about 15% to get sea level equivalency. They are certainly healthy readings.
