Let me be the first to welcome you to BITOG, 1bolt.
I appreciate your trying to "bring me up to speed" so to speak on the issue here, but I have a fair grasp of it at present.
Using hot rod mags as a point of reference is not what I consider to be good information to use. Sure, their followings tend to believe all they print, and will often make reference to them in their arguments, but I see them as a whole lot of fluffy nothing.
Albeit them great stool tools...
Take for example the wise words from one of the articles you suppplied for me to study...this is about all we get concerning the issue:
Quote:
The reduction first started in the mid-'80s, and it has been a gradualprocess, but the latest API SM and GF-4 specs have reduced ZDDP contentto such an extent that the new oils may not provide adequate protectionfor older, flat-tappet-equipped vehicles running nonstock, performancecams and valvetrains. And it will only get worse; projected future oilspec revisions will likely reduce ZDDP content even more.
Some guy saying the new oils "may not" have enough ZDDP is what I'm supposed to get started with?
The same guy (from a cam company) that gave the mag this interview also stated that the cam companies were NOT putting out bad product. Seems he may have been incorrect on at least one item, huh? Again, a marketeer, with no apparent credentials in tribology, leading another general wisdom campaign. -Answering to the benefit of his product line.
Quote:
How about the fact that Mobil 1 High Mileage -- a new oil -- has an SL rating? Because it's got higher ZDDP levels than the current API SM standards dictate? Why in the world would M1 add ZDDP back into it products when it could get the latest SM rating? Is it because they know a handfull of car geeks will find out and start using it in their flat tappet equipped enthusiast cars and trucks? Or because they know ZDDP is necessary for older flat tappet vehicles. BTW no big "CONTAINS MORE ZDDP" blurb on the bottle here either.
SInce all you are doing is guessing, let me also take a guess....
The formulator provides an increased add of ZDDP in a "high mileage" oil to increase it's ability to better withstand oxidative thickening. They sure don't have gearheads passing around rumors in mind with their formulating. But them, I'm just guessing here...
