10W-40 Maxlife claims ILSAC GF-6A and Displays the API Starburst on the Front of the Package
Muncie, Indiana
I just noticed that the 3 jugs of Maxlife 10W-40 I recently purchased all say that the oil "Meets or exceeds all requirements of ILSAC GF-6A," which I could see if they made a semantic error trying to say that it passes all the tests except the fuel economy related ones which wouldn't be possible for a 10W40 with an HTHS of 4.0 to do, but the front of the packaage shows the API Starbust, this same quirk can be noted in the photos on Amazon's website for 20W50 MaxLife, https://www.amazon.com/Valvoline-20W-50-MaxLife-Mileage-Motor/dp/B00GDH5RBQ . I don't know what's up with this but I wouldn't expect this kind of mislabeling from Valvoline.
Online, towards the bottom of the page it as having SN Plus approval. No ILSAC, strange.
Per API 1509, Engine Oil Licensing and Certification System, the API 10W-40 grade is eligible to use the Starburst, provided it meets all of the performance standards required for ILSAC GF-6A, including fuel economy. (See link below - Section 5.4 on page 16 and Table H-6 on page 150). It is possible to formulate a 10W-40 meeting the fuel economy requirements.
API 1509
API 1509
That chart says that but then when you look at page 150, the actual requirements of GF-6A require sequence VIE fuel economy testing which is a test that can only be performed against Xw20 and Xw30 oils so I think the chart earlier in the document is a catch 22.
