Wouldn’t a Euro oil (like M1 ESP) with MB , VW , Porche , etc. approvals address timing chain wear ?
I don't know how high the bar is set....
Sure but you can't fix weak timing chains with oil.
VW FSI engine family had, broke the chain while parked in gear and handbrake with minimum incline.
All 229.X oils fulfills the same timing chain test. Don't know the specifics for BMW LL04 or how that test compares.
Short OCI is the easiest way to keep chain wear to a minimum.
I would think it broke when attempting to start, it's also often when a belt breaks.
I have begun running Rotella T5 10w30 in several of my engines for many of the comments through this thread.
I love Rotella T5 15w40 in most of my motorcycles.
I have never been a fan of wide spans like 0w30, 0w40 or 5w40..... and certainly not 10w60 (KTM Bikes). In my experience, to get those spans result in very, very rapid shearing. (KTM wants that 60wt dumped after 500 miles. I have always wondered if a top shelf 20w50 would be better....???)
Spot on... but all my rigs are kept in a garage/barn and they never have a cold start less than 35 degrees. On occasion I leave my truck out, but if it is going to be sub-zero, I plug it in.It almost certainly would be better, provided you don't drive around when it's below 0F.
Just being technical here: the "spread" is the same between 10w40 and 0w30. The "spread" is 30 in both cases.Higher viscosity and a smaller spread (E.g. 10w40 rather than say 0w30).
I don’t think it can be analyzed that way. It’s very likely that they can make a 0w30 with less VII than 10w40.Just being technical here: the "spread" is the same between 10w40 and 0w30. The "spread" is 30 in both cases.
Also technically correct! It's not quite as simple as subtracting the first number from the second.I don’t think it can be analyzed that way. It’s very likely that they can make a 0w30 with less VII than 10w40.
The old "German Castrol" 0w30 comes to mind! (should have written that in the previous post...but my mind isn't as quick as it used to be)Also technically correct! It's not quite as simple as subtracting the first number from the second.
I’m still sad that Castrol completely abandoned that formula. It was such a unique oil in many ways and it would have been nice to see them tweak that formula and use it to this dayThe old "German Castrol" 0w30 comes to mind! (should have written that in the previous post...but my mind isn't as quick as it used to be)
Kyocera was supplying that Ketjenlube oligomer technology for Castrol GC and sold it to some Russian company. That is as far as I remember the story. I think the development of other additives made it too expensive. But it was oil like no other. I still think their 0W30 fills that niche spot on the market.I’m still sad that Castrol completely abandoned that formula. It was such a unique oil in many ways and it would have been nice to see them tweak that formula and use it to this day
It really wasn’t the same when they switched it from the green formula to the gold one though. Remember when a bunch of us chipped in to have a very expensive detailed analysis of it done? Then we discovered it was using a combination of base oils unlike any other at the time. I know a lot of people back then thought that it was just the “flavor of the month” but it really was something special, especially for being an off the shelf oil.Patman, Castrol 0W-30 SL/A3/B3 is still around, and is at CT in 5L jugs. No, it’s not the exact same as it used to be, but is as close to old ‘GC’ as we will ever get!
I chipped in on that and found it to be very interesting. Wish we could get it today.It really wasn’t the same when they switched it from the green formula to the gold one though. Remember when a bunch of us chipped in to have a very expensive detailed analysis of it done? Then we discovered it was using a combination of base oils unlike any other at the time. I know a lot of people back then thought that it was just the “flavor of the month” but it really was something special, especially for being an off the shelf oil.
Yeah, cheapening stuff.I chipped in on that and found it to be very interesting. Wish we could get it today.
So you are counting the difference between 0w and 10w as double-the-difference since there is a 5w in between, but you count the difference between 30 and 40 as one grade. I guess you can slice and dice any way you want to...it's still not precise.it's one grade hot, 2 grades winter, so spread is one grade less.
