Oil with best anti-wear for Chevy 3.6 timing chain protection?
TIME + USE will tell!! lots of marketing on anything new BUT ONLY real driving will tell the story!!!! the more tech the more issues can happen IMO!! NOT extending changes as DI makes VERY DIRTY oil + NO thin oils for that 1/4 mpg increase + NOT a fan of any cylinder shutdown !!!
My son has a 2013 Cadillac SRX with a 3.6 engine. I warned him when he bought it (45K miles) about the timing chain issues and the need to religiously change the oil every 5K. He has run it over 200K miles with nothing but tire store and quick lube 5w30 oil changes.
My truck uses Chevy's direct inject 3.6 with timing chains. There are plenty of stories over the internet of timing chain stretch on these engines. Most "experts" attribute that to too long OCIs and dirty oil.
I like to keep my vehicles for forever, and a timing chain job is not something I want to undertake.
I figure selecting an oil with the absolute best anti-wear properties, and frequent OCIs is my best defense against timing chain stretch.
I recognize any oil meeting the dexos spec should be sufficient, but certainly some oils are better than others specifically for anti wear.
Thoughts?
Something with a lot of moly like TGMO.
https://www.stle.org/images/pdf/STL.... Esche_The Role Additive Chemistry Plays.pdf
The early version of these started using oil at a pretty high rate. My 2004 Caddy was always run on Mobil 1 with changes at 20% life remaining on the OLM. By 75000 miles it was using a quart every 1000 miles with a six quart sump. Not many folks are going to maintain the level above five quarts and I think that's when the chains get hit with a combination of wear/stretch and then intermittent low oil pressure on the tensioner causes major malfunction.
Run Pennzoil Platinum 5w30 in my wife's 2008 Malibu LTZ with the 3.6 since new. 85K and she runs great. 5K oil changes.
My friend Bill has told me there is one very common condition they see when a GM 3.6L comes in with a stretched timing chain. The owner doesn't check the oil level and the level is low. The chain wears partially because of a lack of lubrication. There are likely other factors in design, but the only source of lubricating oil is from the oil being picked up from the crank sprocket. When the oil level is low, very little oil gets picked up and the chain wears.
That is totally true - the lack of maintenance combined with the bad original design = a lot of failures. I will say the original issues was real on teh 07-11 model range as my 08 CTS and my parent's same car - both perfectly care for both needed chains before 50k miles so nothing made a difference.
Thoughts?
So I have an 08 CTS 3.6DI purchased new. Ran Mobil 1 since new - needed timing chains before 50k miles. Since the new chains(updated design) I continued running Mobil 1 5w/30 and at 204k miles today all is well. So my recommendation is Mobil 1 5w/30 (regular, EP or HM doesn't matter), PP or any good dexos syn changed 5-6000 miles intervals.
Dexos approved oil. Keep it topped off. Change it often. That is it.
This ^^^^^^ is the ticket.
Keep the dipstick oil level at the Full Mark
Use the most recent SP license. Dexos 1 Gen 3 whenever possible
Buy a quality synthetic that's one grade thicker than the 5w30 written in our Owners Manual. We use 5w40 summer / 0w40 winter.
Change the oil every 3k.
In other words, if you keep using this guideline above, your dipstick oil should not turn black for at least 1k.
Keeping the engine oil clean and and at the dipstick full mark is why we still have the original chain on my daughter's 2016 Acadia
It's impossible to know for sure how many GM GDI 3.6L timing chain issues were due to lack of maintenance or how many were due to parts quality issues.
I recently dumped my 2019 Nissan Pathfinder with 103K miles on it due to timing chain problems with it's GDI 3.5L. I bought the vehicle used in 2019 w/ 25K miles on it. I did 3000-3500mi OCIs the entire time I owned it with synthetic 5w30 (as opposed to Nissan recommended 0w20) and used mid grade filters. This VQ35DD engine is a real problem child if you take a few moments to poke around the innerwebs. I didn't know this until after I bought it.
Ironically, I replaced it with a 2021 Chevy Traverse with the LFY 3.6L. I can't get enough of my timing chains..
Bungee cords stretch, timing chains elongate. Lack of frequent oil change discipline increases abrasives in the lube. This wears the rollers, the chain lengthens, all the predictable problems follow.
Sometimes I think the timing belt design is better.
I like this post. For anyone that owns a chainsaw what happens when the chain hits dirt on a log or the ground?
Instantly there's 2 inches of slack in the chain, not from it stretching, but from wear.
Same goes for dirt bikes. Run them off road and the chains wear out in no time and need constant attention.
So what would cause timing chains and drive sprockets to wear in an engine?
I'll go with a lack of oil and/or dirty oil.
IMO, viscosity and additives are down the list.
I'm using XW40 in a 2022 3.6L LGX Acadia because the used oil smells like gasoline, so there must be fuel dilution
and I want zero oil consumption to help extend the life of the downstream emission control system.
Any full synthetic 5w30 with 5k mile oil changes.
Any name brand full synthetic with 3k OCI. Also, keep the dipstick oil level at full mark.
Also, use either 10w30, 0w40 or 5w40. My daughter's 3.6 was using a quart in 3k when she bought it at 52k. Now at almost 80k and ^^thicker grades"" used, no consumption worries anymore.
