I've seen that statement before. What effect does altitude have on the oil grade?Ford recommends 0w-30 in their 6.8 and 7.3 gas v8's when operating below -4 AND above 5,000' altitude
Mostly - I THINK - because above 5000 feet it almost never gets 100°F+ and can get freaking coldI've seen that statement before. What effect does altitude have on the oil grade?
Pardon my ignorance, but if that is so then why wouldn’t a 0w30 with a HTHS over 3 be sufficient instead? I also think the M1 ESP 0w30 with UOAs performed, could determine if it’s capable of extended intervals. Might be if not short tripped? Just brain storming.If someone made a 0w20 that had a 3.0 HTHS that would be a good option for a GRC but I don’t think that exists out there.
I was just curious as to why there wasn’t really any off the shelf 0w30s in the extended life category. Yes there are a few 0w30s such as Vanilla M1 regular Castrol Edge 0w30.Pardon my ignorance, but if that is so then why wouldn’t a 0w30 with a HTHS over 3 be sufficient instead? I also think the M1 ESP 0w30 with UOAs performed, could determine if it’s capable of extended intervals. Might be if not short tripped? Just brain storming.
Well said!Given that Valvoline R&P has been able to find deposits to clean up even when people have been doing 5k intervals with a decent synthetic, I would say that there is some good evidence that running an oil with better cleaning ability (such as an extended life version) will definitely benefit you in the long run.
It’s not just about getting your engine to 250k here. It’s about getting your engines to there while also keeping them clean, not losing any compression or horsepower or MPG. And not having to add a quart every 2000 miles. Lots of people can reach 250k with any brand of oil. Not everyone can get that far and still have the engine be in perfect condition in every way.
Given the need for 0w in your area, I think the best bet is Amsoil or HPL. I’m sure the cost is quite a bit more compared to off the shelf tho.I was just curious as to why there wasn’t really any off the shelf 0w30s in the extended life category. Yes there are a few 0w30s such as Vanilla M1 regular Castrol Edge 0w30.
But I would love to see 0w30 in the extended life versions because of the fact that they all offer a better overall package compared to the more entry level versions.
It wasn’t as if I needed this oil today. But I felt like it was an interesting topic to discuss. It might be a small niche but it’s something that I wonder about.
We figured that out here:I've seen that statement before. What effect does altitude have on the oil grade?
Name | Specification |
Engine Oil - SAE 5W-30 - Synthetic Blend | WSS-M2C961-A1 |
I think you have the right idea.Given the need for 0w in your area, I think the best bet is Amsoil or HPL. I’m sure the cost is quite a bit more compared to off the shelf tho.Hence this thread. Maybe M1 ESP with a couple UOAs and monitoring for any consumption changes is a happy compromise?
Good thought there!Mostly - I THINK - because above 5000 feet it almost never gets 100°F+ and can get freaking cold
They all offer a euro version in that weight which for the most part pass extended drain interval specs with a big bump in HTHS from 0w20 and a slight bump from 5w30I was just curious as to why there wasn’t really any off the shelf 0w30s in the extended life category. Yes there are a few 0w30s such as Vanilla M1 regular Castrol Edge 0w30.
Very much suitable for TGDI AND GDI motors. The oils pass SP engine tests but that isn’t the intended market so they do not seek approval. Also, some element levels may not be in line with API specs so they can’t display the Donut even though in testing they far exceed requirements.What is the deal with this ESP anyways? Back of the bottle label reads like a Euro oil, and has no API donut. Is it an SP oil or not? Is it suitable for low displacement TGDI's? and GDI's in general?
Digging into the mobil pdf you'll find this :
This product has the following approvals: MB-Approval 229.31 MB-Approval 229.51 MB-Approval 229.52 Porsche C30 VW 504 00 VW 507 00
This product is recommended for use in applications requiring: Recommended by ExxonMobil for applications requiring ACEA C2
This product meets or exceeds the requirements of: ACEA C3 API SL API SN Engine Test Requirements API SN PLUS ENGINE TEST REQUIREMENTS API SP ENGINE TEST REQUIREMENTS
Since the small print of extended drain oils say : “20K miles *or the mileage the OM states” makes the M1 0W30 ESP the best off the shelf 0W30 going at WM for $27 for up to 10K mile OCI’s .That’s a good point, and ESP 0w30 would probably be a great option for a GR Corolla
Interesting, never thought of that angle.And I know that 5w30 will still be good down to some pretty cold temperatures as well but that’s when it’s new. Someone who is using an extended interval with a 5w30 might find themselves in the middle of a tough winter with thousands of miles on their oil and it’s now only a 10w30 (or possibly even a 10w20) Even though it’s rare to see too many days below 0F here in my area, I like having a 0w oil in there just to be safe, as then even with a few thousand miles on it, it’s still likely to be a 5w
Yeah I tend to agree. Mobil1 0W30 ESP is the best offering at WM right now for price/10,000 mile drain intervals. The Mobil1 SP 0W40 is probably right there with it but the 0W30 fits more vehicle weight ranges.Since the small print of extended drain oils say : “20K miles *or the mileage the OM states” makes the M1 0W30 ESP the best off the shelf 0W30 going at WM for $27 for up to 10K mile OCI’s .
The latest Mobil-1 ESP 0W30 VOA here at BITOG does not pass SP specs.Very much suitable for TGDI AND GDI motors. The oils pass SP engine tests but that isn’t the intended market so they do not seek approval. Also, some element levels may not be in line with API specs so they can’t display the Donut even though in testing they far exceed requirements.
The VW and MB specs include LSPI and timing chain wear tests.
What people should really fear is long OCI’s.Not really what I meant. People are more afraid of 0W than anything in my 30+ years of encounters.
It passes the engine test requirements but not the bench test.The latest Mobil-1 ESP 0W30 VOA here at BITOG does not pass SP specs.
Not if controlledWhat people should really fear is long OCI’s.
