CivicFK2TypeR
- Joined
- Apr 15, 2023
- Messages
- 36
Ok, so do you think a 0W30-5W30 would be the better alternative than if I had a 0W20 filled in?
It might satisfy the OEM requirements but far too often that wouldn't be hard to beat. @High Performance Lubricants even states the lacking ability of commodity oils to live up to expectations and often leaves the insides with more crud and varnish than anyone would really want in a engine. I'm going to go out on a limb and say I doubt most people are going to leave a car with that type of potential stock. Too many parts that can add lots of horsepower. @CleanSump , Im not saying any of this to argue just simply putting an opinion out there. I think a true synthetic with a Grp 4 or 5 is gonna be better for this car. There are many great boutique oils out there that deserve to be the fill of the crankcase to give it only something good enough.OP, you're overthinking it.
Any oil with the required specification/licensing is G2G.
Membership in BITOG should teach one that maybe one oil can be perceived as "better" than another, but anything that satisfies the OEM requirement is fine.
ESP 0W30, ESP 5W30, ESP X3 0W-40 they're all very close in specifications and manufacturer approvals, I'd use any of them pretty much interchangeably.mobil one esp x3 0w40 will be good,too? The nrw esp 5W30 will be api sp,too. Mobil one is s very good idea i think. Thanks.
Try this if you can find it on sale. Sounds funny to state that a car "likes" it but the engine in my B13 Sentra grocery getter is silent with this stuff coursing through it's veins.Thank you for your recommendations, I will follow midsaps c3.
If you are going to the track and its a turbo...maybe try Royal Purple HPS or HPL oils for the track.I also have a Type R, but a 2019 (FK8). Currently running QSFS 0W-20 and an A02 filter and one FilterMag SS250. Just fell out of the powertrain warranty. Thinking about tracking the car a couple times a year, adding power mods, and thus stepping up in viscosity. Been reading about QSFS, M1 ESP, and M1 EP 5W-30 and I think I'll go for the ESP. Should cost me about $50 in oil per change (5.7qts), every 6 months/6k miles (if I even drive it that much). Looked at Valvoline European but it only has Porsche A approval whereas ESP has C. I'm in the southeast US.
Haven't looked into HPS but I was looking at HPL. Which HPL do you think would be a good choice? I was looming at this non-VI 5W-30, not sure what to think of it. Like if it's so great, why is it just now a thing? If I did HPL, I'd probably do a 12 month/12k mile OCI, it's the only way I could justify the cost. And I guess a Fram Ultra.If you are going to the track and its a turbo...maybe try Royal Purple HPS or HPL oils for the track.
I am only an hour away from ATL, took my accord to the track back in the day but its an NA motor and all it needed was a radiator.
You keep referring to ACEA and temperatures in Celsius so you must be in Europe (??). I've never seen Honda refer to ACEA for engine oils over here.The manual says 0W30 or 5W30 in ACEA A5/B5. 0W20 may only be driven by Honda Engine type 2.0 0W20. This applies to Europe. If ACEA A5 is allowed to be driven fullsaps, then ACEA A3 should also be driven, at least theoretically.
Looking at the OPs short posting History they appear to be in Germany.You keep referring to ACEA and temperatures in Celsius so you must be in Europe (??). I've never seen Honda refer to ACEA for engine oils over here.
In America, an API is specified in 0W20.
