Using a ACEA A3/B4 oil in a A5/B5 engine
Hello! This is my first post on this forum, so I'm sorry if i sound like a noob user.
I've been doing some reading on this forum and online but I'm still unsure of what I should do. Here is my situation.
I have a 2015 XC60 T6 (3.0) with 123k km (~77k miles) on the odometer. The manufacturer calls for 5w30 or 0w30 grade oil with a5/b5 spec. I've always used Castrol Edge 5w30 (#02011) and in winter redline 0w30. I change my oil at around 6-8k km or 5k miles-ish (spring and fall)
It might be worth mentioning I live in Quebec where in winter -20C is not unfrequent.
Now, i dont really want to use redline because of the steep price and availability. It always did a good job tough.
Castrol, which is cheaper, and easily available, I noticed about 1/2 quart missing in my intervals. No drama, but still.
With the reading and learning i have done, it seems I could use a ACEA A3/B4 instead of the original a5/b5, which would offer better engine protection (my goal) vs fuel economy (not that important)
Am I right? Is it that simple? Any recommandations on a better oil to use ? I have easy access to some Castrol products, Liquimoly, Total, Redline, and some Mobil 1 products trough my work.
Thanks for your imput!
Here are a few previous discussions on this topic, they may be of use. Also an Infineum presentation on what the different ACEA Sequences mean. The only real difference is lower HT/HS for A5/B5.
https://www.infineuminsight.com/en-gb/resources/acea-oil-sequences-brochure/
Try Mobil-1, for winter and summer. My experiences with Castrol is their A3s and A5s consume about the same amount oil oil. So if getting off the Red Line train is in your near future, try Mobil-1 oil. They have EPs - Euros and ESPs..... all good stuff. The only ones I avoid are their AFE (vanilla flavors),
Often on sale:
https://www.canadiantire.ca/en/pdp/...ic-engine-motor-oil-5-l-0287963p.html?rq=0W40
Did alot of reading on the subject today (thanks to the links shared by KSCHACHN)
So i really think i will try out a a3/b4 spec. oil for this winter. Now it's only a matter of finding the right one (ouff)
So far I Mobil 1 FS 0w40 sounds great (and on sale at walmart for 35$CAD/4.73L not too shabby)
Castrol 0w40 Euro (02018 canadian p/n)
I'll do some research on Gulf oil that i can get GX/ULE versions.
thanks alot!!
The T6 loves thick oil. I’ve even run HDEO 15W-40 in mine with no issues. But I usually go for a 5W-40 A3/B4.
Currently trying Valvoline Restore and Protect 10W-40 in it to help clean it up and hopefully reduce oil consumption a bit.
No need to stick to A5/B5 at all.
I've used Mobli 1 0w-40 in my 5 cylinder Volvo a bunch. I think it could be a good one for your climate, while offering great protection and cleaning abilities too. You should find this pretty easily available.
Right now I'm using the Valvoline Restore and Protect 5w-30 in attempt to help oil consumption.
A A3/B4 5w-30 would give you a slight bump up in HTHS vs A5/B5 but still have good flow during cold months & keep fuel economy benefits. A 0w-40 A3/B4 could serve the same but with less fuel economy.
Nathan I looked at the product data sheet for the Redline 0w-30 you had been using. That does look like a really nice oil, in my armchair opinion. haha
The Volvos from these years can have the carbon buildup on the rings and cause the consumption to increase with mileage. The rings were a poor design.
Your regular oil changes probably help with that a bunch, but that redline is such a stout product, I also wonder if it has helped you along the way too. Just knowing this potential Volvo issue the way I do and the headache it can cause, I might be tempted to keep using Redline at least part of the year like you were doing.
Ayrton; i totally agree, but in this case, redline has been on B/O for over 6 months at my workplace, and it's 50% more expensive than most of the oils i can get (shame to flush it at such intervals)
i've done a little data collecting collage from the specifications i could collect of the oils I can get and sounds like decent candidates;
closest from the castrol edge a5/b5 i'm using and redline 0w30 i've used would be the Total Quartz 9000 Energy 0w30
There are no fuel economy benefits with 5W30 A3 compared to XW40. Both have minimum HTHS at 3.5.
Some XW30 have higher HTHS than some XW40. Motomaster 5W30 MB229.51 that is available in Canadian Tire will have higher HTHS than Mobil1 0W40.
In the sense of not putting hundreds of thousands of miles on our passenger vehicles like they do semi's it may not matter much. You see in big Semi's licensed for 80k lbs it may be more easily "measurable" but in our light passenger vehicles may be harder to see differences. But I'd have to see some actual tests conducted on the subject first to make a good conclusion.
I really do not know what that has to do with what you said.
There will be no difference in fuel economy between A3, C3 oils in XW30 and XW40 grade. They ALL have to meet SAME fuel economy requirements required by MB, BMW, VW and Porsche.
My statement was regarding A3/B4 vs A5/B5 as the topic asks. Are you saying there is not any difference in fuel economy between those two standards?
