Acea a5/b5 vs a3/b4 cold crank pump ability
Denmark
Hi all.
An earlyer tread mentioned something about cold crank pump ability. That made me wonder. Does anybody here know.
If we have 2 different 5w30 oils; in this case two different European synpower . One is Acea a5/b5 the other one is a3/b4, I know the a5/b5 is lower on overall viscosity including the HTHS. But how much difference will there be on the cold crank pump ability?
Have a merry Christmas.
Søren
A5/B5 oil would probably have lower kinematic viscosity then A3 oil in same grade, but since both are 30 grade difference is probably small.
Given that it's cold temperature pumpability, regardless of what the KV100 and HTHS are, they have exactly the same limits on SAE J300 with respect to the extreme cold pumpability.
If you are needing the extreme cold end performance, the A5 is probably going to have an edge, albeit very very small, as the 5W covers the performance requirements.
Any reasonable sort of starting temperature, and the positive displacement pump will be pumping.
