ACEA A5/B5 REQUIREMENTS
Michigan
My understanding to qualify to be a A5/B5 oil the oil needs to meet A1/B1 and A3/B3 specs. If that is indeed the case , why wouldn't the labeling on a oil bottle list A1 A3 A5 approved ? But the do not , they list A1 and A5 . They is a good chance im just over thinking
No, not really. A3/B3 oils do not have to meet any fuel economy requirements. A1/B1 and A5/B5 need to have an improvement in FE of 2.5% greater than reference oil (15w-40) The oil in your picture is not A3/B3.
Might be hard to see the oil in picture is 5w30 pp. So im wrong in my conclusion that to be A5 it has to meet A1 and A3 ? Im aware that A3 is not a fuel efficiency standard . On a side note in my Vw 1.8t gen 3 by switching from Mobil 1 0w40 to Castrol 0w40 both A3 oils i have seen a decent mpg increase . I do a fairly short oci . Engine sounds much smoother also
Incorrect. They are different specs. A higher number does not mean it meets all the lower number specs.
Also A1/B1 has been removed from ACEA sequences as of 2016, so it is an extinct spec.
Refer to my sig:
The best MPG, and smoothest and quietest running engine, in my Dodge B2500 was from the oil in my sig. I tried everything from 5w-20 to 10w-40. EXACTLY the same results with the Ford Ranger. The Ranger owners manual called for 5w-20 but the engine was originally designed for 5w30. No major engine changes from 1993 to 2005 that were oil related.
Originally Posted by BMWTurboDzl
It's possible to have an oil certify as both A3/B3 and A5/B5 but it, for example, would need an HTHS of exactly 3.5.
Yes, this - to the point that we'll never see one. It'd be much like having A3/B4 and E7, E9 all at the same time.
