Castrol Edge Vs. Castrol Edge EP
So I could not find any concrete discussions on the difference between Castrol Edge and Castrol EDGE Extended Performance. I normally do 60K OCI on my cars so I was curious.
I asked Castrol if there was a difference in base oils or additive packs. This is how they replied. I'm guessing there are just some differences with the add pack. Any input?
Thank you for contacting Castrol North America.
Castrol EDGE is a premium full-synthetic engine oil. Castrol EDGE has an oil change interval of 20,000 miles or a full year (whichever comes first) under certain conditions, thanks to its use of premium base oils and additives. Castrol EDGE carries the latest API performance level (API SQ) as well as specification coverage for most vehicle OEMs.
Castrol EDGE Extended Performance is Castrol’s most advanced full synthetic motor oil. Also, a premium full-synthetic, Castrol EDGE Extended Performance utilizes advanced additive chemistry to even further increase performance, the strength to enable an extended drain interval of 25,000 miles or a full year (whichever comes first) under certain conditions, and carries additional European ACEA claims on top of the claims coverage of our standard Castrol EDGE.
Castrol EDGE 0W-20 & Castrol EDGE 5W-30 both meet the following specifications:
  • API SQ / ILSAC GF-7
  • GM Dexos1 Gen3
  • Ford WSS-M2C947-A, WSS-M2C947-B1, WSS-M2C962-A1
Castrol EDGE Extended Performance 0W-20 meets the following specifications:
  • ACEA C5, C6
  • GM Dexos1 Gen3
  • Chrylser MS-6395
  • Fiat 9.55535-CR1, 955535-GSX
  • Mercedes Benz 229.71
  • Jaguar/Land Rover STJLR.03.5006
  • Volvo VCC-RBS0-2AE*
Castrol EDGE Extended Performance 5W-30 meets the following specifications:
  • ACEA A5/B5, C2
  • GM Dexos1 Gen3
  • Honda HTO-06
  • Chrylser MS-6395, MS-13340
Castrol always recommends following the guidelines of the engine manufacturer for the recommended oil (i.e., SAE grade, API rating, and manufacturer specifications) specific to your application. This information can always be found in the owner’s manual or by contacting the manufacturer directly. Before using any lubricant, ensure that the lubricant product specifications meet or exceed the lubricant specifications required by the Original Equipment Manufacturer (OEM) for that specific use.
Thank you again for contacting Castrol, we value your patronage!
Castrol Customer Relations
ADKq_NbhwrQzTSD-wqvsTFAnTqo77JU5CcBzpF4OZAEkFbkgMgYJWKe4zCglNq5mWrH8vTiaKIjUOaknEh8Do1QIDaxS359oCUsoQw3Qkgu-8c-8omSBk-f13DT6h1C9T4Yn7WMp3CKPn_z3mWNZg9zdC-dg9vmrJt4l4Ggh27yVuq4JP-xjjvrumwk=s0-d-e1-ft
  • GM Dexos1 Gen3
  • ACEA C5, C6
  • GM Dexos1 Gen3
  • Chrylser MS-6395
  • ACEA A5/B5, C2
  • GM Dexos1 Gen3
  • Honda HTO-06
60K OCI? Is that a typo?
I'm wondering if the Castrol EDGE Extended Performance 0W-20 version having four more certifications for the Euro manufacturers is any reason to use it year around vs the 5W-30. I wouldn't think so, but that's what I am using right now and the plan was to switch to the 5W-30 for the summer and fall.
No. I'd run 5W-30 year round unless more wear for 1% better fuel economy is preferable to you.
