I run 5W30 in my 2012 Tundra that the owners manual says to use 0W20 for better fuel economy.
beside viscosity choices that Toyota allows anyway, Ihave bypassed lockouts such as the requirement to be in4 low to run an electronic locker. so that I could run the locker anytime and Used the hell out of that mod to drive down the beach without having to use 4wd unless I stopped.I have 2006 Holden (Opel) Astra and the owners manual says to use 10W30 or 15W40 in ACEA A3/B3 or A3/B4. That's it. No other viscosity is listed, and no other standards like API are listed.
First oil I ran was Valvoline DuraBlend 10W40 A3/B4 semi-synthetic, close enough. Followed by other name brand A3/B4 10W40s as they are cheap and plentiful here.
I also ran some full synthetic A3/B4 oils such as Castrol Magnatec 5W30, Shell Helix Ultra 5W40, and Valvoline SynPower 0W40. Still no great risk, as they still carried the correct Euro spec, even if a slightly different viscosity grade, mostly the winter rating - which is nothing in my hot climate.
Probably my biggest deviation was Mobil 1 5W30, which was a ILSAC GF-5 and Dexos1 oil, so completely off grade and off spec. But hey, years down the road, and I'm still driving the car.
That is knocking on the door of "breaking bad".I've run heavier weight oil than spec'd. I've done transmission services when supposedly it's a "lifetime fluid". I've changed spark plugs sooner than suggested, and also later. I've used different weight differential fluid than spec'd - because I didn't want to be bothered finding or buying 75W85 and instead ran 75W90 (oh the horror). I've run higher air pressures too. I'm pretty outrageously daring, and often considered the life of my bingo parties.
We’re modern day Walter White’s.That is knocking on the door of "breaking bad".
I too have been an outlaw all of my days by not shifting manual trans models into whatever top gear is by 31 mph. I also do not believe in the existence of lifetime coolant and lifetime ATF. I don't care how many credits that earns you in the home nation.
The SRT 0W-40 is meant to be a fuel-efficient (250ppm Moly and 600ppm ZDDP) mid-SAPS lube. It wants to be an ACEA C3 oil, but it's not quite there yet. It's not quite as good, or even close, to a Euro lube with the appropriate approvals and certifications.I'm kinda deviating from mine by using a Euro 0w-40 instead of the SRT 0w-40.
The funny thing is that in some model years, they published in the owner's manuals that, for 3.6L and 5.7L HEMI engines, in the absence of 5W-20 that meets MS-6935, the owner may use 5W-30 that meets FIAT 9.55535-S1 or FIAT 9.55535-S3. Now, FIAT 9.55535-S1 is your average 5W-30 ACEA C2 oil. Ironically Castrol EDGE and Castrol EDGE EP 5W-30 meet this specification, but Pennzoil Platinum and Ultra Platinum 5W-30 don't. For the sake of the discussion, let's say that any ILSAC 5W-30 will do for a lowly gas engine.2014 Jeep GJ 3.6 and 2016 RAM Limited Hemi 5.7 both call for 5w/20 but I run 5w/30....over 100k on each just fine. I deviated from the 5w/20 spec recommended for 2 reasons:
1. These motors were originally spec'd for 5w/30...changed to 5w/20 I feel just for fuel economy gains as there were no motor changes that would need 5w/20.
2. I feel 5w/30 is a better fit for these motors - the Ram tows a lot for example.
Note - I support 5w/20 where motors were designed from the get go for it.
(smilies go with the pic, not laughing at your post)That is knocking on the door of "breaking bad".
You are being kind, I tend to think of it as a tarted up 5w-30 in drag, masquerading as a 0w-40The SRT 0W-40 is meant to be a fuel-efficient (250ppm Moly and 600ppm ZDDP) mid-SAPS lube. It wants to be an ACEA C3 oil, but it's not quite there yet. It's not quite as good, or even close, to a Euro lube with the appropriate approvals and certifications.
