What kind of wood is this?
Erie, PA
Looking to see what this is from left to right. Google lense was about zero help.
Notes. If you label from left to right 1 thru 4, 1 is heavy, and has green in the center, 2 is heavy and we have no clue what it is, we suspect maybe ash but most are dead from the ash boare, 3 is feather light compared to the rest, and has unique dark markings, and 4 we suspect oak.
Its not for any prize. I needed to identify as we need to process alot of it from a roadside. I wanted to focus our efforts on the best woods for burning before it gets poached / loaded up by passer bys.
Its a friends property we are not stealing it from a roadside. The power company went thru and dropped a bunch of trees so they would not grow into the power lines.
So far (and I have spent hours googling)
1 = Tulip or Poplar
2 = Ash (confirmed)
3 = Maple / Lindentree / Basswood
4 = Red Oak (confirmed)
1 = Tulip or Poplar
2 = Ash (confirmed)
If #3 is as light as you say I'd go with basswood, maple is dense and heavy and we don't have lindentree where I'm at but we do have basswood and it's pretty light compared to Oak or Maple, it's also relatively soft.
Pennsylvania has similar hardwood species to Michigan. These look to be about 6 to 8 inch diameter, so we're looking at younger bark/cross sections (cookies). The bark appears wet, which throws off the color. Clear closeups of the cookie endgrain would assist.
- Tulip (yellow) poplar (typical heartwood).
- Ash Species
- Maple Species , but the "very light weight" throws me off. Could be one of the less dense maples like red/silver/mountain. The basswood guess is appropriate, but the photography throws everything off.
- Oak Species probably one of the red oaks (pin,red, black, etc).
EDIT: Looks like #3 from the left is the only questionable one.
These were cut with the 545 Mark II .325 18" .050 with new old stock LPX chain ( or whatever it was before the EXL.)
I did not know tulip and poplar was the same but that solves that one.
Yes #3 is the mystery remaining. All the wood is soaking wet, and it is feather light compared to the others. I guess silver maple would be a good bet.
You have to be careful with common names and regional dialect differences.
Tulip poplar/yellow popular is one species: Liriodendron tulipifera
The populus genus includes the species quaking aspen (populus tremuloides), bigtooth aspen (Populus grandidentata), and balsam poplar (Populus balsamifera). Often people will call these "poplar", popple, or bam (balsam poplar).
Poplar may not mean the same from region to region.
EDIT: I scoffed at the above suggestion #3 might be pine, but that bark could be white pine. Take a whiff and see if it smells resinous, like turpentine.
I did exactly that after I cut it. No smell of pine which is where I became lost. No turpentine no sap on saw no resin. Must be a maple / basswood.
