Found it. This is just fyi.
I cut & pasted it. Hope he doesn't mind ... also being out of context!
From SonofJoe:
The idea that 'wear' in general is primarily dependent on aggregate base oil viscosity (as opposed to VII 'enhanced' viscocity) has been around for yonks. IIRC, some of the industry standard wear test read-across tables are predicated on this principle.
Having said that, I'm not sure if I buy into the theory. If VIIs were to shear away to nothingness, I might agree, but it never does. Even high SSI VIIs (especially OCPs) are, in real life, remarkably robust. You have to remember that OCP VIIs contain a broad, bell-shaped distribution of polymer chains and only the very heaviest shear down.
Also the idea that VII polymer chains are in some way 'squeezed out' of tight gaps, and so cannot influence wear, seems to me fanciful. An expanded polymer chain, with all those surrounding, occuled base oil molecules would be indistinguishable from base oil itself. What next? Do additive molecules like Ashless & ZDDP get "squeezed out', in which case I completely wasted 13 years of my working career!
Talk to oil formulators and whatever Nissan might say, the prevailing view is that timing chain wear is impacted by chain metallurgy & manufacturing way, way more than oil quality. Yes they still have to run & pass the requisite CW tests and yes, they probably claim great results for 'their' oil but in their hearts, do they truly believe this to be the case? I think not...
Another post:
I'm going to go out on a limb here and say that however hard you look, you won't find a single professional oil formulator out there that genuinely believes engine oil has anything to do with TGDI timing chain wear. Timing chain wear problems are a function of chain design, manufacture & metallurgy.
The amount of 'soot' you accumulate in oil in a TGDI engine is miniscule when compared to that of a diesel engine. Any modern gasoline oil contains exactly the same componentry as diesel oil to deal with that soot (primarily ashless dispersant).
And treat all that twaddle about TGDI soot being particularly 'hard & abrasive' with a massive pinch of salt . Exactly the same thing was being said about diesel soot several years when Cummins were bleating about their crosshead wear problems.
Yes, timing chain wear is now a specified engine test that has to be passed by oil formulators to get spec approvals but has this actually changed the way oils are formulated? I could be wrong but I'd bet serious money that it hasn't.
