The above linked study was rather interesting. However, I suspect the test was run using rather low viscosity oil. My speculation is that additives become the lubricant when oil viscosity is too low to prevent rapid wear.
For over 100 years, industry has been using chains for power transmission, often in seriously heavy duty applications. So chain life was a major factor in operational costs, machine accuracy, down time and so on. Industry studied the problem and found the longest possible chain life required just two things. 1) 30 viscosity oil. 2) extremely clean oil.
Despite what many here say, oil changes are the way to remove micro particulates from your engine oil. Unless one is performing particulate counts and knows the percentage of soot in the oil, extending OCI's beyond the severe service interval is risky.
We've known about chain wear forever. This is nothing new and surprising. Timing chains have been failing for as long as they've been used. With wildly differing results on the very same engine models. The reason for early failures remains the same as it's ever been.
My suggestion: Choose a quality synthetic oil of sufficient viscosity, change it frequently. The Ford Ecoboost chains that are failing take 25 man hours to change and the parts cost is near a $1000. That's nearly $4000 to replace chains, often before 100,000 miles. The oil change is cheap insurance.
