Where are you seeing that 229.52 requires TEOST 33C? Because I'm not seeing that in the Afton handbook.
Just a google search. So it could be wrong.
Ahhh yes, good old AI.
Here are the slides from the Afton handbook for all the MB approvals:
Now, I'm not seeing TEOST 33C anywhere there![]()
As I said, I suspect it's as simple as I posited, that all these oils carry the basic API approval, which means they are subject to TEOST 33C and that necessarily limits their moly content.Well, that’s good, it scratches possibility 1 off my list.
That may not be cost effective, but I think we would see levels increase.Do you think if TEOST 33C was removed from API we would see a few blenders with HPL levels of Mo in approved oils?
I know what happens when you assume things (I'm retired US Army), however here I go. Would it be safe to assume if these different higher end oils that do so well on the turbocharger deposit testing would be better at not causing or allowing the oil ring coking/sticking on these newer low tension piston ring engines than say off the Walmart shelf API rated oils also?I'm not privy to that information and have not seen turbo center section teardowns after use. Can you share some photos of what you've seen?
Amsoil and Mobil have shown some images after the demanding GM turbo test.
There is talk and there is data. 300,000 engineers are going to provide data if they're good engineers.
I would expect HPL to show excellent results in a turbo despite the TEOST 33c results.
So within the licensed world you have your basic low-cost budget blends (just meets the spec/bulk oil etc.) and top tier brands (Mobil 1 Extended Performance/Pennzoil Ultra Platinum/Valvoline Restore and Protect) that greatly exceed the baseline tests, and cost more. The boutique brands can formulate to their own higher standards which in theory should generally be better across the board, and they sometimes are. The only potential downside is when boutique companies top treat/modify existing add packs, hopefully under the guidance of the additive supplier, you run the risk of having an unbalanced formulation. However the well know and respected boutique blenders - Amsoil, HPL, RL, know what they're doing and have years of experience.Would it be safe to assume if these different higher end oils that do so well on the turbocharger deposit testing would be better at not causing or allowing the oil ring coking/sticking on these newer low tension piston ring engines than say off the Walmart shelf API rated oils also?
To answer more directly, there are many off-shelf oils that will do a fantastic job at keeping rings clean under OEM OCI. Those would include Mobil 1 Advanced Clean / Mobil 1 Extended Performance, Pennzoil Ultra Platinum, Valvoline Restore and Protect, Mobil 1 ESP.
In theory, a boutique oil has the potential to be better than a licensed product because they're less restricted and not formulated to a price point. The major brands have economy of scale, but it's still a price battle on the shelf and they're chemically restricted in some areas. To actually quantify though where the improvements are with a boutique brand can be tricky. We saw TiGEO use HPL in racing and it gave him better shear stability. So that was a measurable difference. For deposit testing, it's unclear. In theory yes, the boutique brands should do a better job at keeping rings clean. There is a leap of faith though because you truly don't know. The brands I mentioned have great reputations.
I prefer testing results. I always have and I think it's important. That doesn't mean oils without them aren't as good or better, it simply means they fall into the "should be better" category.
Here is an example of what Amsoil does, even for their CVT fluid. You don't need this information to make a good decision, but I like to see it.
Thanks for the great reply to my questions here @buster I do appreciate it.So within the licensed world you have your basic low-cost budget blends (just meets the spec/bulk oil etc.) and top tier brands (Mobil 1 Extended Performance/Pennzoil Ultra Platinum/Valvoline Restore and Protect) that greatly exceed the baseline tests, and cost more. The boutique brands can formulate to their own higher standards which in theory should generally be better across the board, and they sometimes are. The only potential downside is when boutique companies top treat/modify existing add packs, hopefully under the guidance of the additive supplier, you run the risk of having an unbalanced formulation. However the well know and respected boutique blenders - Amsoil, HPL, RL, know what they're doing and have years of experience.
Is there an oil that has VW 504, MB 229.5X, Porsche C30/40 approval or even Dexos 1G3 license with more than say, 300 ppm Molybdenum?
I think he's referring to this thread:Show these spectrographic analyses that have a >2X difference in results on the same sample please. Different blends, sure based on the treat rate of the specific additive. But no way on the same sample. ICP plasma temperatures are extremely high and decompose even the most stable oxides.
In my latest communication with Lake, I asked why his molybdenum levels typically report significantly higher than Blackstone and Oil Analyzers. He said their lab uses RDE vs ICP.Thanks, I added the Amsoil to the VOA Database. I wonder if SPEEDiagnostix has never included Titanium on their reports? I'm just noticing it's not on there. I know they don't include Silver, Barium or TBN.
I found a few on the Russian oil club site that were between 200 and 300, but nothing 300+.There’s no OEM approved euro oil with more than 150 ppm that I’ve seen of late. The BMW 10W-60 has 200 ppm but it’s just an A3/B4, BMW has no actual spec for the 10W-60.
Except, Castrol doesn't always do that. Longlife III is for 504/507 & C30. No MB approval. There probably wasn't an equivalent MB spec Castrol thought it would be a good business case to include getting current manufacturer approvalI just mean that for economy of scale, it would seem logical to pursue both VW/Porsche and MB approval with one blend to alleviate the extra cost of having a dedicated blend for each.
I have used this product with success on a 2015 Honda CRV that started a VVT actuator cold start rattle on cold start at about 60,000 miles. That particular 2.4L engine was known for the issue. This Liqui Moly MoS2 stopped that rattle, saving me money, not having to fix it properly with replaced parts.You can buy the MoS2 additive separately and give your oil that silvery dark gray color also from Liqui Moly
That would explain it, RDE is better for gross screening rather than accurate results.I think he's referring to this thread:
This last OCI, I sent samples to Speediagnostix (RDE) and Wearcheck (ICP) and their numbers tracked very closely, well within the margin of error of $35-$70 used oil analysis testing.That would explain it, RDE is better for gross screening rather than accurate results.
Yep, and if you are worried about fuel, choose a lab that uses GC, which means it can't be Blackstone.This last OCI, I sent samples to Speediagnostix (RDE) and Wearcheck (ICP) and their numbers tracked very closely, well within the margin of error of $35-$70 used oil analysis testing.
Even LSJR says pick a lab and stick with it. You're not looking at individual numbers, but the overall results across many samples, aka "trend analysis" (I know you know this, @kschachn, but not everybody does). Whether a labs' testing method is "good" or "bad", they should be relatively consistent. You lose the consistency when switching labs.
Yes a test has both repeatability and reproducibility. Both an ICP analysis and the RDE will or should have corresponding ASTM procedures which will give you repeatability and reproducibility as long as the test procedures are performed in accordance with the test. You really should not lose a lot between labs, I seriously doubt the reproducibility is really that bad. I know it isn’t for ICP.This last OCI, I sent samples to Speediagnostix (RDE) and Wearcheck (ICP) and their numbers tracked very closely, well within the margin of error of $35-$70 used oil analysis testing.
