VVT and thicker oil
Myrtle Beach, SC
I recently read an article vehicles with Variable Valve Timing, it is important to stay with the specified oil grade, or it can throw a code, cause the vehicle to run rough because the timing is slightly off, oil is not getting to where it needs to..
Neither here nor there, there is a lot of people on here, that run different grades of oil, with VVT, so obviously this can't be true, and I even read where oil geek, ran 0w16 with 0w8 was specified. In his daughter's Toyota.. so is this only certain vehicles??
Thank you
I call 🐂 💩 on that. VVT has never been bothered by an oil grade in any of my Toyota, Lexus, Honda, Mazda, Hyundai/Kia, Infiniti, Nissan, and GM vehicles.
VVT HAS been affected by fresh and clean oil though. When it gets cleaned out (after previous owners abuse/neglect) and starts operating properly - then the performance difference you can feel is night and day. In a couple cars I had to resort to Marvel Mystery Oil for VVT solenoid cleaning, and it worked in few hundred miles. In severe case I revived a sticky 2JZ-GE VVT solenoid by letting it soak in Berryman B12.
But VVT being affected by an oil grade or viscosity? Never. Only Clean vs Dirty/Sticky.
Edit: I can only think of one case. A Pontiac Vibe with Toyota 1ZZ-FE engine. It has seen every grade from 0W-20 to 15W-50, (even 25W-40) in my ownership. One time I did an oil change with Valvoline MST 5W-40. Immediately the car lost all its pep, super slow, almost like it was pulling a trailer with another Pontiac Vibe on it. I thought it would go away, but it didn't. So I changed the oil again with something else from my stash, and the issue instantly went away. So my wild guess is that Valvoline MST 5W-40 did something to the VVT solenoid or cam gear assembly. No other oil ever did that before or since then.
My buddy is running Mobil 1 0W40 in his VVT 3.6L second generation Pentastar engine. No problems to report, even in the dead of Upstate NY winters. IIRC that engine has 0W20 stamped right on the fill cap. ;)
I was talking to a guy last night that has a repair shop, he has a GMC Denali and his customer was running the wrong grade of all, the customer tried putting the right grade in still did not take care of it..
Thank you
Yes some older Volvo V70 2.4t can shoot a fault code when the oil is too thin/old & hot (past regular OCI) for the VVT solenoid.
Ran the Honda CRX d16z5 with everything between 5w30 > 5w50.
