Coyote vct system vs oil grades
Edmonton, Alberta, Canada
I have been using 40 grades for the last 3 years on my 2018 5.0 in an F150. I may just start using 5w50 as I can get it from the dealer. Just recently I replaced my vct solenoids due to a rough idle and stalling issue. Which seems to have fixed the issue so far. Warranty did not cover these as I had no check engine light / codes. So I paid out of pocket. Some things I’ve seen in datalogging is that using lighter oils you get really low psi at hot idle. Which doesn’t allow for the vct system to operate properly causing issues. I’ve found that heavier oils give higher hot idle pressure and it runs much smoother. The smoothest my truck has ran has been on rotella 5w40. But it’s become hard to find and expensive around here. On lighter oils the desired cam angle is not able to be kept by the intake cam phasers and it will swing from 15-45 degrees when 30 is the target angle. Causing a very rough idle and occasional stall. Touching the accelerator bringing up the rpm and hence oil pressure fixes this right away and it’s able to keep the cams where they should be. I supposed as things wear and age they just don’t work as well.
Here’s some info I have saved from a well known tuner for these:
The noise is not coming from the DI pump. It is being caused by the DI pump, but the noise itself is typically the exhaust cam phaser on the passenger side. The added load of the DI pump and the stiffer valve springs in Gen 3 motors put a lot of extra force on that cam.
At very low loads and RPM, the oil pump is barely making 20-25 psi of oil pressure, and very minimal flow. So, then the VCT solenoids open to allow oil to enter the phasers to rotate the phaser, there isn’t enough pressure or flow to fill the galley quick enough to rotate the cam, and there’s a small amount of air inside the phaser for a split second, while the cam is being commanded to rotate. That causes the phaser to “rattle” back and forth until oil fills the galley and rotates the phaser. Is it ideal, no. Is it hurting anything, highly unlikely.
Now... why does it happen tuned and doesn’t happen stock. That’s because in our tune, we schedule the DI system to come online earlier, at lower loads and lower rpms. We do that, because this being a 12:1 CR engine, it needs all the knock protection it can get, especially if you choose to run low octane fuel. Direct Injection direct cools the cylinder, greatly increasing knock protection and performance. So, it’s a valid trade off. Better protection from something that definitely will hurt your engine, knock, versus the slight chance that if you feather the gas pedal juuust right, you’ll here the cam phasers rattle.
Let me be very clear this is not “ping”, “knock”, or “detonation” like everyone likes to describe any noise they ever hear an engine make. Trucks that have this issue will make the noise even with E85 in the tank, and it’s essentially impossible to cause knock on one of these engines on E85, without obscene amounts of boost. So.... it’s not knock.
Another easy test you can do yourself to prove to yourself, that “maybe” I might actually know what I’m talking about. When you hear the noise, press the pedal down just a little more. What this will do is instantly increase oil pressure and flow, abs the noise will stop. Now, if this were knock, increasing load would have the exact opposite effect. You would cause more knock because the cylinder pressures would increase with the added load/throttle.
Lastly, for everyone that’s hearing this noise, you should all check your oil levels. Everyone knows these trucks have oil consumption issues, and of the dozens of times I’ve explained this to various people 90% of the time the person complaining of the noise was down on oil.
So, things you can do to improve or eliminate the noise. First, make sure your oil level is full. I personally run an extra 1/2 quart of oil in all of my Coyote engines. I do this based on recommendations from several well known engine builders. Coyote engines tend to have a hard time with oil drain-back when driven hard, and that can leave you with an oil pan that’s basically dry at WOT. Adding an extra 1/2 quart is a good way to help with that, and have adequate oil flow will also help with this noise. Second, run 5w50 oil. It’s perfectly safe for any Coyote engine, and the added weight can increase oil pressure at low loads, which can help with this problem as well.
And another article from him:
More info to share. I've touched on the tip-in "rattle" a few times, and what cuases it. It's often mistaken for knock, but it's not knock. The noise is coming from the VCT system, and is typically the timing chains slapping against the guides. Ford has issued an SSM for the noise.
Reading through the SSM, you'll see that the very first troubleshooting step is to verify oil level, as low oil level will cuase the VCT system to not have enough flow or pressure to proeprly actuate the VCT phasers at low RPM/Load. I would add onto this further and also note that we recommend, and use, 5w50 weight oil in all of our Coyote engines. The added weight will increase oil pressure under the same operatring conditions versus Ford's recommend 5w20 weight oil. Before anyone attacks me for recomending "non-recommended" oil weights. You should know that any high performance version of the Coyote (Boss 302 and 302S for example) and also Roush, who sells vehciles at Ford dealerships with full factory waranty, both recommend using 5w50 weight oil. So, any one experieincing a tip-in rattle at low RPM/Load, might want to consider these troubleshooting steps.
To further add to this, the range to fault the DTC codes mentioned in the SSM seems to be pretty large. I have seen datalogs from several trucks with VCT control issues that are not faulting these DTC codes. Most of them are easily sorted with switching oil weight and making sure the oil leve is full at all times, but some have actually required repalcing the VCT solenoids. It would probably be difficult to get the solenoids repaced under warranty without the DTC codes present, but for those experiencing rough idle, stalling, or tip-in rattle, the info in this SSM could be benficial.
[https://www.tsbsearch.com/Ford/SSM4...b2PIlEKjE04jIh8Td8Uo_9DQkvzCR0LR7pApnjCsfYbk)
How many miles on this truck?
Just over 50k miles on mine. They looked good. But replacing them has fixed my issue. I’ll stick with shorter intervals I think and 40 or 50 grade oils.
Not much for higher volume or pressure pumps. The mustang pump is 60 thousandths bigger. Many upgrade the oil pump gears when going boosted to keep them from breaking.
Here’s pics of mine during the process. And the 4 vct solenoids that were replaced. Engine looks pretty clean so far. But I still have had an issue with them.
This is all very interesting, ty for posting. Maybe this is the reason Ford went to a belt driven oil pump and 5w30 spec for 2021+. But they also reduced oil fill capacity . . .
Ford also went with 5w30 in the Coyote in the Mustang, which does not have the belt driven oil pump, nor cylinder deactivation like the Coyote in the F150.
Link to the SSM doesn't work in your quote ... but here's a link that does work.
https://www.tsbsearch.com/Ford/SSM4...sb2PIlEKjE04jIh8Td8Uo_9DQkvzCR0LR7pApnjCsfYbk
Sounds like Ken Osborne is talking ;) but yeah 5w50 works fine. I’ve been running it in my 2019 f150 with a five liter. Mine has the phaser rattle too. Even on the stock tune It’s really bad on 87 octane but disappears on 93/e85. I too thought it was pinging, but data logging proved that to not be the case.
The motorcraft 5w50 is really expensive. I think I paid right at 12 dollars a quart for it.
Should I be running a 40 or 50 grade in my 3.7 F150? From what I understand it has a similar valvetrain to the 5.0, my engine definitely has “tip in” rattle at low rpms that goes away with more throttle. Never knew quite what it was till I read the above post. Never has presented any problems other than being annoying. Im currently running Mobil 1 High Mileage 10W30 with a Fram Ultra at 5k ocis. Runs very quiet with no issues.
Yea unfortunately in the year I have been dealing with this (except for winter when it’s cold here and I had zero issues with this) I have not been able to get it to leave a code. I spoke in depth about this with the shop foreman. He didn’t believe it was the vct solenoids at all. I’ve seen countless posts of people with the same issue and changing them seems to have fixed it. So I told them to change them out on my dime. Sure enough I haven’t had the problem since and it’s been getting warmer outside. I even towed my boat and it didn’t act up once. Seems like ford isn’t just replacing these unless they have a code that tells them which one to replace… I wasn’t taking a chance so we did all 4 of them.
Because the OP mentioned:
"Warranty did not cover these as I had no check engine light / codes."
It always helps to really read the OP's original post carefully. I do want to thank the OP for making this thread and I will say that with VCT this is a winner for the repair shops and and a loser for anyone that owns an engine with this miserable idea.
If it were an oil volume problem, the 5w-50 wouldn't help, the pump moves the same volume of oil regardless of viscosity as long as the pump isn't on the relief.
If it is an oil pressure problem, as @Taildragger noted, an HV pump would produce more pressure (by trying to move more volume) which strikes me as the easiest way to confirm, however, without one available, that of course makes it difficult to actually test.
Interesting issue though.
Why not just use the factory recommended oil viscosity? I personally know over a dozen folks with 5.0 coyote powered trucks and none of them have any VCT issues. I’m also friends with an ac repair guy who owns his own company. His fleet of F150’s all have the coyote and none have any VCT issues or noises. Most of them are serviced thru Ford dealerships and quick lube shops which I assume use the factory recommended oil viscosity. I highly doubt any of them have been filled with anything thicker than a 30 grade viscosity.
