FatBloke007
- Joined
- Jan 16, 2026
- Messages
- 6
Hello all, new member here. Had some interesting observations which may be entirely plausible, however I can't find any reliable information to help me make sense of it.. hence I thought I'd ask.
The situation is the following:
- Car is a 2011 Volvo XC90 with the 4.4L Yamaha built V8. DOHC with VVT. Current mileage 83.7k.
- I've owned the car since early October last year. Dealer provided an oil & filter change prior to handing over to me. My assumption is the dealer filled up with 0w30.
- Over the past 2000miles I have performed 2 oil drains via the dipstick with a Vacuum pump, each time extracting ~5L of the ~6.7L in place.
- I refilled with Shell Helix 0w40 as per https://www.shell-livedocs.com/data/published/en-GB/0e8580ed-9627-4d62-ad0d-c904a7a03a0d.pdf
- My thinking was this oil is relatively cheap, high quality and may do a decent job of 'cleaning up' whatever lies within. (This notion may well nonsense?)
- My intention was to run the car with a 0w30 in the winter. Hence I have recently again removed 5L via the dipstick, and refilled with Shell 0w30 ECT C2/C3 as per https://www.shell-livedocs.com/data/published/en-GB/e7ec61ff-5983-4ab2-b8c9-b240f654f5be.pdf
- Filter has not been changed on any of my drain/fills.
- This 0w30 oil has a different additive package as far as I can tell.. Boron heavy.
So the car currently largely runs on 0w30. I expected slightly improved fuel economy overall, with reduced losses on cold starts.. however, I have consistently observed poorer mpg on my regular 15-20mile journeys, since changing to the 0w30. I appreciate there are many variables at play when considering fuel economy.
My question ultimately is, all else being equal, is it possible for an engine to be less efficient with a lighter oil weight in operation?
